**SOLD** Tru-Cool 4454 Transmission cooler
jusgroovin
I'm asking $50 shipped anywhere in the CONUS. Brand new, just took it out of the box to inspect and photograph. I went with a B&M 70264 instead.
It's GVW rated at 18,000 lbs., size is 7 1/4 x 11 x 3/4, 36 cooling plates.
I realize that this is only my 2nd post, but I just purchased a 99 4runner SR5 4WD about a month ago and have been updating maintenance items on it.
Anyways, if you are in SOCAL it's available for pickup also for $40. I am in downtown Long Beach.
Bump for a great product, i installed this on my 4runner...if you own a 3rd gen you should know if your radiator leaks where the tranny fluid enters it they will mix and can cause harmful damage to your tranny.
This is such a cheap and easy modification you would be silly not to do it.
thanks for the bump. no takers? make me an offer.
universal kit
Is your tranny cooler a universal? And will it fit on my 2001 4 runner?
thanks
Charlie
YOU will not lose any coolant. You will however, lose about 1/2 qt of ATF when you disconnect ATF the hoses from the stock cooler.
and also, the cooler has been SOLD.
thanks for looking.
so...if i plan on doing this...do i need to add more coolant at the end or anything?
