Someone Please Help!
sant6236
My HID's from Xenon Depot have been increasingly flickering, but ONLY when I stop abruptly with the brakes. What the hell is this about??
Somone has to know what this is.... Its gotta been power, ground or current related.. But, why only when I use the brakes??
Is my battery going soon?
Seems like it might be newtons laws in action, have you checked that everything is tied down and wired well? The abrupt stops are probably causing something to shift just enough to compromise the circuit. The battery, alternator and related components are not directly involved in the showing down of the vehicle so this should not be an issue.
Either that or what about the brake lights compromising the ciruit? But, if this were the case everyone else would more than likely be experiencing this.
I am going to need to go through everything (all hardware, wires, etc) and ensure they are properly secured.
not sure if this will help, but make sure the harness attached to the original bulb wires are secure. When I first installed the HIDs one side didn't work because one side on the plug connecting to the harness popped out the back if that makes any sense. This plug controls when the lights turn on and off so it may fix it for you.
Absolutely valid point and I am going to check that. I know exactly what you're talking about, as I noticed the same thing when installing them. Those little plugs on the back pop out very easily.
Just going to have to run through the kit very thoroughly.
goddesszilla
