psraff
It does help. Any info helps. I'll have to work on the rear sway bar when I return. My pinion angle is fine. To adjust that I would get rear adjustable uppers. I'm getting lowers to fix the axle not being square.I was just asking because I was missing rear also do to broke bolts and had to drill and tap them. I'm currently at 4* caster and when it was missing had same issue on highway. She is pretty solid now. The rear sway bar helped dramatically. Went from unsafe feeling to completely safe. Months back I installed adjustable Panhard and had rear aligned. That helped a lot also. I don't see how adjusting rear pinion angle with adjustable lca's will help.
I'm getting aligned Saturday on g. I did still notice some rub when pulling into drive way quickly even on g with 33's. Hope alignment helps.
Sent from my SM-G920I using Tapatalk
