speakers, amps, sub, misc audio $75-$300
toyotadave79
I have an almost complete system for sale. Most of the items are lightly used, and some have never been installed on anything. Most of this is Memphis and Hertz products so they will last a while with some love and care. This was going to be a competition setup but we have decided to put our time and money on other projects.
(2)- Memphis 16-MCD500 (bottom two)
http://www.memphiscaraudio.com/documents/MCD.pdf I also have the bridging module needed in order to run both amps at the same time. Both of these amps were going to be wired to the one sub.
(1)-Memphis 16-MC2004 (old fin style dark chrome)
- RMS Power 4 ohm (Watts) 50 x 4
- RMS Power 2 ohm (Watts) 75 x 4
- THD 4 ohm 0.03%
- Frequency Response +/- 1 dB 10Hz-50Khz
- Dimensions (in.) 6.5 x 2 x 11.875
(1)-Memphis 1 farad digital cap. (old style original)
(1)-Memphis 15” Mojo This is a Beast!!! will not ship. I will drive up to 30 miles one way. I am in 27610. Any more than that, you help pay gas.
It is currently wired at 3.9 ohms. Box dimensions are 33.5x19.5x17.125 with a port of 15.5x2.875
(2) pair of Hertz Hi Energy HCX165 oversized 6.5 also called 6.75. Barely used.
You can get all the info from here: http://www.hertzaudiovideo.com/doc/hertz_hienergy_hcx165.pdf
(1) pair Memphis MSQ 5.25-$75
(1) pair Hertz Energy 6x9- $75
(1) Phoenix Gold 1000.1 sub amp- $250
(1) Phoenix Gold S400.4 Highs amp (Blemish on top) see pics
(2) pair hypnotic tweeters HK1
Hypnotic Audio
(4) stinger 2.5” square fans- $25 for all 4
With all of this I also have a bunch of wires. A lot of 4 gauge wire in which you will need to use coming off a distribution block. This system you should have or look at doing a 0 gauge install. I have some Memphis wiring like a 5 channel RCA cables. PM me for more pics and if you have any questions.
sorry guys been out of the area for a while.. The only thing I have left is the sub and one of the 500 amps and a cap. I will let all three go for $450. Pickup only
