Speakers
jkdenson
The only speaker currently working is my back left. Every so often, the front right speaker will turn on just long enough to scare the crap out of me and then goes right back out. Any suggestions on where to start to try and fix this?
I would start at the speaker. Pull one out and connect a known good speaker to it, can be almost any speaker to try temporarily even a house one. If still dead then you will need to work your way toward the head unit. From what I've seen a no/intermittent sound issue is sometimes a broken wire where the wire flexes between the door and chassis, a bad speaker or a loose connection. Speakers are pretty cheap to replace, Crutchfield breaks down the options well.
tuṣṭāva
