Speed Sensor Test??
MattinAZ
Hey folks, I am chasing an ECM code #10. My main relay tests within spec all be it a little high. 75 and the spec is 60-80. The next test according the FSM is the speed sensor. I found it on the tranny next to the fill hole but the FSM doesn't give any info on testing it or the circuit. Am I missing something? Any ideas would be appriciated. Thanks.
On another note, I am torn between a crawl box with 2.28 and tcase with 2.28 or just going single w 4.70. I understand the loss of standard low with the single. Whats the general opinion on this???? I'm leaning toward the double 2.28s right now.
The 4.70 case is a little less expensive, and would be lighter. Like you say though, dual cases lets you keep standard low, and gives you twin-stick trickeration as well. If I had the money, that'd be the route I'd go.
mek
