Speedometer in Kms??
steuny
I imported my 4Runner and want to get a instrument cluster from miles to Kilometers. Is there anything else that needs to be done other then change the cluster. Will the car start measuring in KMs. Thanks for any info to help me out.
Thanks for the reply. Yes, the cluster has both but easier to read depending on which is on the outer. Are these clusters interchangeable in that I can replace mine with one that reads kilometers and it will be accurate .
A cluster from the same generation should swap in and work.
You may have to change some things, for example if you current cluster has an oil pressure idiot light and the new one has a gauge, you would need the oil sending unit for the gauge also.
Giordano Schoenwetter
