Speedometer incorrect on 265/70/17 tires
Really the more important question is why did you put OEM Duelers on your truck? :)
My OEM Duelers were off by 2 mph. My Revos were dead nuts. Looks like my new Michelins are off by 1-2.
4th Gen and newer 4Runners utilize the ABS Speed Sensors to determine an average vehicle speed that is sent to the instrument cluster.
There is a roughly 2mph allowance in accuracy for the speedometer (there's a more structured variance in the FSM that has a progressive tolerance as speed increases IIRC at like 70mph and higher it gets in the 3~4mph range of variance).
It does sound like you did a fairly good job of verifying the speed difference so that's good, usually I have people using those speed limit signs on the side of the road; which I have found to be very inaccurate. GPS apps and units may be accurate depending on the quality and model and software coding, I would say that the E-Class might be fairly accurate, but again they also allow a variance of about 2mph (it's sort of an industry thing, typically the variance is more that the speed is faster than the actual vehicle's speed.)
There's an SAE standard out there about these variances. Something about a 4% or 5% allowance across the full range of the speedometer is allowed, caveat being that it's just an SAE standard and not a regulation/law in the US and it doesn't have teeth.
I'm spot on under 40 mph, but see 5% at 75 mph. Between 0 and 75 it's probably less than 4% average. I can't test beyond 75 mph, so there's no telling how far off it is north of there, and no real point in testing anyway because I'll never have any need/desire to go faster than 75 in this thing.
Standard for anyone interested:
J1226: Electric Speedometer Specification--On Road - SAE International
Haha it is a long story, but a few weeks back I was going through some issues with two local dealers ref: a bad driver's front wheel bearing growling north of 30 mph. The dealers kept saying it was tires, I had bald (sub-20k mile) Dunlop AT20s that were 2/32 - 3/32 already and figured what the hell.
So I had the dealer replace the tires themselves (so they couldn't point at 3rd-party purchased/installed tires) as a troubleshooting step. TL;DR it didn't fix the noise, the wheel bearing was the issue, and they eventually replaced it under warranty after much gnashing of teeth. I also got a 20% discount on the tires, free mount, balance and alignment because they were wrong. I mean, they still cost more than the set of K02s I just bought for my 3rd gen, but this is just the wifemobile.
Plus, if they wear anything like the AT20s (read: awfully)... I'll be replacing them in 8 - 10 months anyway.
My two cents: Have owned numerous various model Toyota's. With exception of the T4R, found the speedo to be accurate with stock tires/wheels compared to GPS tracking. (Camry's, Highlander and Rav4's)
Both my 4th gen and 5th gen T4R's found the speedo to indicate 2MPH faster then GPS tracking.
Do know that a few years back, there was a class action suit about this same issue related to deliberate speedo settings allowing for faster then actual speed that also resulted in vehicle coming off warranty a couple of hundred miles before actual travelling miles
No wonder! I've noticed that with my 4runner, cars were passing me all the time when I'd do 70 and I just thought that everyone was driving faster that day. I only have 2000 miles on it, so still new to me in the car's driving dynamics.
I have the same problem its off by 2 MPH above 50. Can a speedometer collaboration be done on these new systems? My 13 SR5 was the same way.
Can you confirm that the odo gets its data from the same sensors?
Yes, all the newer Toyotas use the average between all 4 wheel speed sensors to determine "Vehicle Speed" that is then output from the ABS module via typically a dedicated "VSS (Vehicle Speed Signal" wire to the combination meter where modules like the ECM and Navigation will ask for that data from the Combination Meter.
As far as I am aware there is no calibration mode or adjustment to the Combination Meter.
Speedometers always read high. I did not check out your link. But years ago I had done some research and the thing with speedometers is on a stock tire size, the car should NEVER read slower than the car is going. As mentioned its a percentage error biased on the high side.
This helps to prevent "accidental speeding" (and allows for a margin of error)
Cop cars have calibrated speedometers.
As for my 4R, its dead nuts.
On a side note, If I was to get pulled over for speeding and asked how fast was I going, I could have said, no clue, speedometers read high. Now I can't.....
BillM777
