Speedy's Lift Install with "How To" Video
Speedy
Member
A month or so back I asked about doing a mild lift on my 2002 4Runner and got a lot of good advice here: 2" Lift on 3rd Gen? - Toyota 4Runner Forum - Largest 4Runner Forum
That thread has meandered a bit, and now that the lift is installed I wanted to start a fresh one with the information I obtained and the "How To" video I put together for the install process.
I had a few requirements for my lift. I didn't want more than 2" of lift. I wanted to use as many factory parts as possible since I knew they'd have a higher chance of availability down the road, and I didn't want to spend a fortune on the setup. I also needed a NICE highway ride and absolutely did NOT want anything harsh at all. The 02' 4Runner had almost 100K miles on it so the suspension needed some freshening up and this was a good opportunity to upgrade.
After advice from folks here, THANKS!, I went with Tundra TRD Coils from a 2000 - 2006 model Tundra, Bilstein Tundra 5100 shocks that are 5 way adjustable up front, and OME 906 coils for the rear also with Tundra 5100 shocks. Wheeler's advertises the rear shocks as 4Runner specific, but the actual part number is from a 2000 - 2006 Tundra like the front.
The Tundra TRD coils you want are marked with a Yellow/Yellow paint mark on one coil and Yellow/Blue paint mark on the other. You can find these in salvage yards, but the ones I found in my area weren't much cheaper than brand new so I just got new ones from an online dealer. Google search and you'll find some deals as the prices change quite often it seems. If you wanna try the salvage yard route you can search Car-Part.com--Used Auto Parts Market.
Here's the parts you'll need:
Tundra TRD Coils:
Left Coil Part Number: 48131-AF100 Y/Y
Right Coil Part Number: 48131-AF090 Y/B
Tundra TRD Bilstein 5100 Shocks:
Front Part Number: 24-188265
Rear Part Number: 24-100144 (Wheeler's lists these as BIL 4R5100)
Old Man Emu 906 springs
Tundra Coil Spring Isolators Monroe P/N 907926
Everything else can be re-used and there is no need for a diff drop or adjustable pan hard bar for 2" of lift. If you go more than that then you should look in to those additions.
The ride is fantastic. It's firm but compliant and I would describe it as better than stock. The suspension soaks up bumps with just a faint thump that you barely feel in the cabin. The 5100 shocks are awesome. I got exactly 2" of lift as you'll see in the video as I took measurements before and after to show exactly how much was gained. The install wasn't too bad, but I got lucky with the rear top shock bolts so YMMV.
Hopefully this video helps some folks out there with the install. I tried to cover everything. You can watch it in HD on Youtube if your internet connection supports it.
Here's some pics along the upgrade process:
Before new tires and wheels. Stock suspension IS TRD wheels and stock tires.
After 265/75R15 Bridgestone Dueller A/T Revo 2 tires and Level 8 MK6 wheels. To me, the larger tires upset the lines of the vehicle at stock height. I was getting just a bit of rubbing on the driver side inner fender only.
After 2" lift. For me this is perfect. Not too high and gives nice body lines and proportions for the tire/wheel combo.
Nice work Speedy. I appreciate the extra time you put into your installs from having to work in camera angles and commentary.
I know you didn't post this so everyone could tell you how they would have done it. There's more than on way to skin a cat, but I just want to offer a couple of helpful tips...
On the front I always separate the upper ball joint. You don't need a special tool. Just whack the side of the spindle just below the ball joint with a small sledge hammer and it will come loose. It will allow more droop and make the install of the new spring slip in easily. My Toytec 3" springs along with the Tundra Bilsteins on the second perch slipped right with little effort. In addition, I used the factory dust boot on the 5100 shocks in the front.
On the rear when I went to tighten the nut down on the top shock mount, I pulled the boot down from the top to expose the shaft, wrapped the shaft with a piece of an old bicycle inner tube and used my vice grips on the upper part of the shaft to keep it from turning. The inner tube keeps you from scarring the shaft. Then I slid the boot back up and pushed it back into place.
I've been waiting for you to post this and without even looking at it I want to give you a huge thanks. Shocks and springs should arrive tomorrow meaning I will be spending this weekend flat on my back with my baby above me!
I really appreciate the video on the rear suspension, I have done the front, but I need to replace the rear coils and your video made it look a lot easier than I expected.
Thanks everyone. Hopefully it helps some folks out and saves time as some of this I had to figure out as I went a long.
Those are good suggestions, especially on the rear. I thought about separating the upper ball joint, but with 100K miles on the clock I had visions of it giving me trouble during the re-install. It was going to be my last resort if the jack trick didn't do it.
The rear is cake if the upper shock bolt comes out without issue. Pre-soaking for a few days in WD40 is time well spent.
Seriously well done tutorial. Thank you!
Did you have any issues with the alignment afterwards?
Friday is install day for me. Your vid will help a LOT. Only difference is that I'm adding the 10mm trim on the rear to maintain 1/2" of rake after settling.
Again, great job.
Again, great job.
Mine's got 500 or so miles on it and still sits 1/2" higher in the rear just for your info. Not sure how long the 906s take to settle?
If there were any issues with the alignment, the shop didn't say anything to me about them. Just gave me the alignment sheets and took my Benjamin for the work.
Thanks for the heads up. I put a lot of weight in the back on a regular basis. I'm guessing I will settle (crush) my new springs in no time.
Even though there are plenty of HOW TO's and DIY guides for lift installs, you're videos and narrating are so thorough its very refreshing to watch. As always awesome camerawork and video.
Im thinking of replacing my rear OME shocks with billies and its good to know the exact part # i will need.
Thanks !
Um... that was amazing. Like a professional TV show. I'm sure this is going to give a lot of first time lifters heaps of confidence. Wish I could have had this when I lifted my truck. Great job. :hail:
Ha! Thanks! Maybe PowerBlockTV will offer me a job :spy:
[MENTION=65101]BrianSD_42[/MENTION] [MENTION=24995]SV_Dude[/MENTION] ^^^^ Make it so! (add to informational directory that is :D)
Jhunt
