Spindle Nut - Size of Socket?
gman72
Hello all,
New to the forums here - go easy on me pls :p
Need to replace the front rotors and CV boots, check the bearings, etc .... on my 1994 Toyota 4Runner 4WD, my old baby, but it's been neglected since I bought my '03 Limited :cool:
I assume I need to pull the spindle nut to get everything to come off. Hayne's manual is worthless for details on this stuff.
I was told that the nut was a 54mm (or 2 1/8") ... so I picked one up from Sears (2 1/8") and it doesn't fit? Do I have the wrong size?Does anybody know where I can get the correct tool for the job?
Thanks much!
Gman
Here's a couple photos to clarify the situation .... Socket doesn't fit ... any tips?
My bad ... guess I should've cleaned more grease off to see that the lock washer was what was causing the socket to not fit. Thanks for the info ... helped out - 5 min. later rotors are off and I'm continuin' the job!
