Spring Time Maintance
Just Replaced Sway Bar bushings, Sway Bar end links, Tie Rod end also replaced all four ball joints with Moog Ball Joints. Rides just like new again.
Also replaced the Timing belt, water pump, idler pully and tensioner pully at 186880 miles, the belt had no cracks that I could see. Transmission fluid replacement with amsoil is up next,
I need to do the same. Where did you buy the parts? Also, did you replace any bushings in the rear? My rear suspension has started to make a funny noise and I know it needs new bushings.
H.Sikina
