CBR_GUY_IA
NOTE: This bulletin has 5 sub bulletins and goes three replies long
Steering - Highway Speed Steering 'Flutter'
Information
Diagnostic Procedure
Dunlop Tire Flat Spotting Diagnosis/Tire Balance Procedure
Steering Rack Guide Preload Spring Installation Procedure
Increased Mass Steering Wheel Installation Procedure
#1
STEERING
ST001-05
REVISED
July 28, 2005
Title:
STEERING FLUTTER FIELD - FIX PROCEDURE
Models:
'03 - '05 4Runner
TSB REVISION NOTICE:
^ September 8, 2005: The contact information in the "Obtaining Replacement Tires" section of the "Dunlop Tire Flat Spotting Diagnosis" procedure has been updated. Previous versions of this TSB should be discarded.
Introduction
Some customers may experience a steering flutter condition while driving at highway speeds. In most cases, this concern is caused by flat spots that can normally develop in the tires after sitting for long periods of time. To minimize the effects of flat spotting and other minor tire irregularities, a new repair procedure has been developed that includes installing improved components to help reduce steering flutter complaints.
Applicable Vehicles^ 2003 - 2005 model year 4Runner vehicles produced BEFORE the Production Change Effective VINs shown.
Warranty Information
Applicable Warranty:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Production Change Information
Parts Information
Required Tools & Material
Required SSTs
#2
Notes
Notes
#3
Notes
The following instructions apply only to black sidewall P265/65R17 110S Dunlop AT20 original equipment tires produced in Japan before the production week 0905. Tires produced on or after production week 0905 do NOT qualify for this program. The last four digits of the tire DOT number represent the production week. This procedures does NOT apply to vehicles equipped with Dunlop AT20 original equipment tires produced in the U.S.A.
After the tires have been warmed up for a minimum 10 minutes at 65 mph (104.6 km/h), the vehicle should be immediately raised on the hoist. The tires may be checked with a dial indicator placed at the center rib of the tread design.
If the tires are flat spotted, there will be a short duration dip in the runout gauge reading equal to the approximate size of the tire's footprint, or approximately 3 - 7 inches (7.6 - 17.8 cm) of the tread circumference. The dip in the reading on the runout gauge will go in and out the same amount; it is not just a short duration but an abrupt change in the reading. Flat spotting will NOT be visible by eye and requires the use of a dial indicator. Flat spotting should NOT be confused with any external abrasion on the tire (such as a panic stop) that causes the tread depth in the tire's footprint area.
If the runout between A and B exceeds 0.020 - 0.040 inches (0.051 - 0.102 cm) over 3 - 7 inches (7.6 - 17.8 cm) of the tread circumference, this may cause a ride complaint depending on the vehicle sensitivity.
If the tires are not flat spotted but the assembly runout is greater than desired, then standard match mounting and balancing procedures should be followed.
Obtaining Replacement Tires:
Tires with 9/32 or greater tread depths that are flat spotted based on the above criteria may be exchanged at no charge through a Dunlop dealer. It is recommended that all four tires be exchanged when flat spotting has occurred. For dealers participating in the Toyota Tire Center Program, please contact Program Headquarters for instructions. For dealers not participating in the Toyota Tire Center Program, your local Dunlop dealer must call the Goodyear/Dunlop Customer Assistance Center at 1-800-321-2136 for authorization to return the tires through the Goodyear/Dunlop warranty system.
Mount the tire/wheel assembly to the tire balancer as illustrated. When balancing the tire, ensure that the Road Force function of the balancer is turned ON and the "Haweka" type balancing adapter MUST be used when balancing these tires. (Refer to your balancer owner's manual for further information about Road Force variation measurements on tire and wheel assemblies.) This is necessary to ensure that the wheels and tires are match mounted (heavy portion of tire is matched with light side of wheel or visa-versa).
Remount the tire and wheel assembly to the vehicle. Torque all wheels.
Torque: 112 N.m (1,142 kgf.cm, 83 ft.lbf)
Information
#1
STEERING
ST001-05
REVISED
July 28, 2005
Title:
Models:
'03 - '05 4Runner
Introduction
Parts Information
Required SSTs
#2
Notes
Notes
#3
Notes
