yotaah said:This is from memory when I did mine but it should be pretty close....
It wasn't too big of a deal, it is located on the passenger side of the truck, relatively easy access through the wheel well if you turn the wheel all the way to the left. Biggest problem I had was that I think you have to remove a section of brake line to do it correctly which results in having to bleed your brakes when you are done. Other than that, pretty straight forward.
Who mentioned taking out the battery???Ron Helmuth said:expand on this remove the battery thing....
I had never read about that before.
So I spent about 3 hours on this today and could not get the top bolt off. I was using 3/8" long extensions but could not get it to break with my Dewalt cordless impact. Would a half inch work better. Any thoughts?
