starter removal
johnny c
I think I have a problem with my starter (occasionally stops cranking) Are these a problem to remove? If so, does anyone have any "tips" on removing it? It is a V6 automatic. Thanks in advance.
This is from memory when I did mine but it should be pretty close....
It wasn't too big of a deal, it is located on the passenger side of the truck, relatively easy access through the wheel well if you turn the wheel all the way to the left. Biggest problem I had was that I think you have to remove a section of brake line to do it correctly which results in having to bleed your brakes when you are done. Other than that, pretty straight forward.
You don't need to remove the brake line at all. Remove the retention bracket on the inside of the frame (12mm) and bend it out of the way.
If you've never done it before it's a ***** the first time, you need to disconnect the battery, jack up truck on jackstands, remove wheel (RH) , remove body-frame splashshield. Remove Automatic transmission dipstick, remove the upper dipstick tube.
Then remove the starter, easier done by using a long extension with a swivel 14mm socket and remove starter bolts and remove the electrical connections.
Bend the brake lines downward and towards the rear, but not too much and bend enough to remove the starter.
Now, you don't have to replace the starter, only replace the starter contacts. There's 3 8mm bolts and an access cover, remove that and replace the contacts in the order they are installed. Take the solenoid plunger end that contacts the electrical contacts and clean it with a fine sandpaper.
Install is reverse.
I did my starter twice in one month cause I bought a dud, and I will tell you this, I will never do it myself again, I have been working on cars since I was bout 13, you name it I prolly done it, but I will pay someone to change my starter if it goes out again, I screwed up my rack&pinion lines tryin to get the damn thing out and now I go through a quart of power steering fluid about ever 2 months, but it is doable
There is some real good info on this thread.
The starter is not all that hard to get out through the wheel well. As mentioned above, just remove the brake line mount and CAREFULLY bend the line out of the way (doesn't need to be moved too much). I did NOT take my wheel off. Some people say the top bolt holding the starter on is a real pain to undo, but I had no problems at all using a single extension on a 3/8" drive socket wrench (but I'm stronger than most too). The hardest part for me was getting the starter turned just right to get it out of the opening in the wheel well above the frame member.
Check out my 2 posts in the middle of the thread I linked. New starter contacts can be had for ~$10.
alot of people say they took theirs out through the fender, my physically would not fit through the gap, I played with the damned thing like a rubics cube, if mine ever goes out I'll pay one of you guys to replace it
Thanks so far, I'am sure it is a contact issue. I have a hoist, so getting under isn't an issue. I did hear somewhere that they were a little tough to remove so I thought I would see if anyone had a tip or two in order to make my job a little easier. I thank you for your time and information!!!
I was able to clean off the terminals w/o removing the starter using a wire brush, mine did the same thing - either clicked or wouldn't turn at all. Its been over a year since i've had any issue, and i never had to remove the starter!
Do you mean the terminals on the outside of the starter (battery) or the contacts inside solenoid. I believe my contacts are either burnt or worn. I fixed one on an older 4runner that had bad contacts, easy fix, still a pig of a job to get out!!!:rant:
Even though it's doable with it on. I don't see why you guys would not take the wheel off, it's six lug nuts and you have more room to wrestle that starter through the small opening. I'd seriously go nuts if I had to crouch and lean over that damn tire.
remove the battery?
expand on this remove the battery thing....
I had never read about that before.
I agree that taking the tire off sure makes a lot of sense to free up some room....
Re: remove the battery?
I actually thought it was easier WITH the tire on. It gave me a nice smooth surface to lean against and leverage myself. It might be a wee bit painful leaning against the A-arm, rotor, and those 6 lug bolts sticking out.
Who mentioned taking out the battery??? :confused:
thanks for the advice
Just followed everyones advice. Replaced the contacts on my starter, took it out throught the wheel well.. Worked out great. thanks all!
So I spent about 3 hours on this today and could not get the top bolt off. I was using 3/8" long extensions but could not get it to break with my Dewalt cordless impact. Would a half inch work better. Any thoughts?
Break it loose with a ratchet, then use the gun to spin it the rest of the way off. Youre probably not getting direct rotational torque on the bolt head with the angle.
Pay someone to do it, it is a pain. its very tight, and getting to it to take the out you will need a special tool as its very difficult to get to. look it up on youtube, I tried it and gave up and had a mechanic friend do it.
I think Konkordmusk is right, my first thought was the impact don't have enough a$$ to break it loose.
Also, I read somewhere on here that it was easier to drop the starter out of the bottom of the truck by removing the sway bar. Not sure if that works best or not but when mine gets ill I will look at that option as well as the side removal. I have read where guys pulled it from the side, no problem, and then read where some guys could not get it out the side...
I don't understand why people have such a hard time with this. Find the videos that are floating around and follow the advice on this forum.
I simply used a 20" breaker bar and a few extensions to remove the starter. I pulled it out through the wheel well after moving the brake line and the transmission dipstick. Just watch how its been done in the videos. I removed mine and replaced the contacts in about an hour...and that's without removing the wheel.
I replaced mine a few months ago. Could not get it out of the side. Removed the sway bar bolts and it slid right out the bottom.
tuṣṭāva
