Steering is squeaking
tnoble
180,000km on my 2010 TE and not to sure what is make in the noise up front. Not moving and move the wheel back and forth to hear a noise coming from the drivers side front. Speed bumps will give a similar sound, but thought that might just be the adjustable CA's. This steering has me baffled and a little concerned. Any thoughts?
Lubricate the uniball on your uca's. Couple shots of graphite should do it.
He doesn't have uniballs since he is running LR UCA's. It is a stock type ball joint.
OP, do you know if you have the "new" Spec Ride bushings for your UCA's. They have changed the bushings over the years since they were having sqeaking issues. You might contact SPC to see if they will hook you up with the newest style of bushing.
ok, so lubricate the stock type ball joint on your uca's. Couple shots of graphite should do it.
:becky:
...couple shots of grease into the zerks too
pugowks
