Steering Wheel Pulse, The Struggle is Real
CutthroatSlam
Senior Member
We own a 2014 SR5 with 437,000 miles and a 2023 ORP with 70,000 miles. Throughout ownership we have off and on dealt with the dreaded steering wheel pulse. I do all the maintenance and repairs and feel that makes me qualified to opine on this issue.
Yes it is due to wheel balance or out of round tires. Yes road force balancing helps address it, but I will go further. You need to rotate the tires every 5K, else you will burn the uneven tire wear further into the tire. Rotating the tires front to back, even diagonally front to back, helps scrub the uneven wear off the tires when they are in the rear.
Friday, while my wife was off geocaching and camping in the 2014, I drove her 2023 across the valley to get a hike in. Noted steering wheel pulse at 60-62 mph. Tires are Cooper Rugged Trek AT LT (e-rated) with 10K miles on them. Checked the tread on the front and there was very slight feathered wear on the outside. So Saturday between football games, I rotated the tires diagonally front to back. Did a road test and the steering wheel pulse is completely gone.
I have had similar vibration at highway speed on my 1999 K2500 Suburban. There it was due to flat spotted tires which happened when wheels were locking up due to the ABS module being out of commission. The vibration was very annoying between 70 and 75 mph. Old timer suggested I shave the tires round again. So I rigged up a Makita planer on a cheap Chinesium milling table attached to a piece of plywood and I shaved the tires. Lo and behold, it worked. This further convinced me that it’s the tires.
kadenzack
