Steering Wheel Swap on 4th Gen 4Runner
I have always hated the thin steering wheel on my 2004 SR5, so I've been driving it with a Wheel Skinz leather wrap for the last few years.
I then found a vendor that would re-wrap a used steering when in leather, with added padding underneath, then ship to me for installation. This adventure has not been cheap, nor has it been without issues. I worked without much prior information on how to do this, except for a very old thread from 2005 without pictures.
So hopefully this will help some of you considering doing something similar. The vendor where I purchased this from is Redline Accessories, which you can find here: http://www.redlinegoods.com/SteeringWheelCover.php.
This is the final product. You'll notice that the wheel is not centered, which I've read is due to the manufacturing differences between steering wheels. I hope to remedy this with an alignment:
<a href="http://www.flickr.com/photos/jeremycollins/11343733586/" title="WP_20131212_12_40_22_Pro by Jeremy Collins, on Flickr"><img src="http://farm3.staticflickr.com/2872/11343733586_5d129b15ff.jpg" width="500" height="282" alt="WP_20131212_12_40_22_Pro"></a>
Step 1:
Disconnect the negative terminal on your battery. Some say this is optional, but since the airbag is an explosive device I would say this is mandatory. A 10mm wrench removes this bolt:
<a href="http://www.flickr.com/photos/jeremycollins/11343762654/" title="WP_20131208_10_13_09_Pro by Jeremy Collins, on Flickr"><img src="http://farm4.staticflickr.com/3671/11343762654_7800f5df4a.jpg" width="500" height="282" alt="WP_20131208_10_13_09_Pro"></a>
Step 2:
Remove the two covers on each side of the steering wheel by applying light pressure to the area where the arrow is pointing:
<a href="http://www.flickr.com/photos/jeremycollins/11343762764/" title="WP_20131208_10_02_30_Pro by Jeremy Collins, on Flickr"><img src="http://farm4.staticflickr.com/3708/11343762764_2902a0d914.jpg" width="500" height="282" alt="WP_20131208_10_02_30_Pro"></a>
Step 3:
Once the cover is removed, you'll see the two bolts holding the airbag to the steering wheel. This is a torx bolt, and required the largest one I had in order to remove. It was also on VERY tight, so some muscle helps to remove it:
<a href="http://www.flickr.com/photos/jeremycollins/11343733796/" title="WP_20131208_10_13_23_Pro by Jeremy Collins, on Flickr"><img src="http://farm8.staticflickr.com/7335/11343733796_8387599833.jpg" width="500" height="282" alt="WP_20131208_10_13_23_Pro"></a>
Step 4:
Removing the bolts in step 3 will allow the airbag to lift off the wheel. Disconnect the assemblies at the green and red arrows:
<a href="http://www.flickr.com/photos/jeremycollins/11343733706/" title="WP_20131208_10_24_10_Pro by Jeremy Collins, on Flickr"><img src="http://farm3.staticflickr.com/2828/11343733706_00ea289710.jpg" width="500" height="282" alt="WP_20131208_10_24_10_Pro"></a>
Step 5:
You'll want to remove these airbag connections while the steering wheel is connected to the vehicle. Use a small screwdriver to lift up on the yellow tab, which will then allow you to remove both connections:
<a href="http://www.flickr.com/photos/jeremycollins/11343733656/" title="WP_20131209_09_58_34_Pro by Jeremy Collins, on Flickr"><img src="http://farm4.staticflickr.com/3777/11343733656_dbe99fbdf0.jpg" width="500" height="282" alt="WP_20131209_09_58_34_Pro"></a>
Note: I did not remove these first, and ended up destroying the steering sub-assembly when removing the steering wheel. I learned this part is expensive, and is not something that most dealers stock!
Step 6:
With the airbag disconnected, you can now remove the bolt indicated by the purple arrow. This required a 19mm wrench and a lot of effort:
Step 7:
With the airbag removed, attach it to your new steering wheel. If you have buttons on your steering wheel, this is the time to switch them over:
<a href="http://www.flickr.com/photos/jeremycollins/11343804703/" title="WP_20131208_13_54_57_Pro by Jeremy Collins, on Flickr"><img src="http://farm4.staticflickr.com/3806/11343804703_8aef4644ab.jpg" width="500" height="282" alt="WP_20131208_13_54_57_Pro"></a>
Step 8:
Reverse the steps above to install your new wheel:
<a href="http://www.flickr.com/photos/jeremycollins/11343657305/" title="WP_20131208_13_44_15_Pro by Jeremy Collins, on Flickr"><img src="http://farm3.staticflickr.com/2887/11343657305_0abca2d081.jpg" width="500" height="282" alt="WP_20131208_13_44_15_Pro"></a>
Enjoy your thicker steering wheel! Mine is now about 4 inches in circumference, which is perfect for me.
Here's another place to get it done. It's overseas but looks good and the leather is stretched really tight.
I have used www.carsdream.com in Poland to modify three other steering wheels for my Porsches. I am driving the Tundra more now and didn't like the skinny hard steering wheel. So I sent it off to be covered in leather, thickened and have hand grips added. Total cost wasn't cheap, $250 plus my shipping cost to get it there; another $50. But the feel and look of the wheel was well worth it for me.
Here are some photos of the Tundra wheel and the Porsche ones. The first photo is a stock Tundra wheel next to the modified one;
P1170782.jpg~original
P1170783.jpg~original
P1170784.jpg~original
P1170785.jpg~original
P1170786.jpg~original
P1170787.jpg~original
P1140503.jpg~original
Those look great. The vendor I ordered from messed up and did not put the perforated leather on the sides of the wheel, which I'm really bummed about.
I'll post the name and the link once this issue is addressed :)
Runvod
