Steering wheel wobble when turning.
JLRunner
Hello yall, I am stuck. I am getting a pretty aggressive steering wheel wobble when turning to the left @25mph or greater.
When the weight of the truck shifts to the right side(turning left) the steering wheel wobbles.
It also wobbles occasionally when braking. Rotors seem fine.
I have ruled out bad UCA bushings. Just changed them. Recently replaced lower control arm.
Any ideas? Truck is a 2011 2wd. 296k miles. UCAs changed. Ball joints changed. Shocks and springs upgraded. Sway bar links changed.
Most other suspension components are original. Wheel bearings original.
Thank you in advanced!
Lug nuts tight? (I'm sure you covered this, but just to check) Wheel lug holes wallowed out? Using correct type of lugnuts?
Grab the outer tie rod and see if there's any play in the ball joint in the inner tie rod end.
All bolts tightened to spec, especially LCA cam bolts? Has alignment cams moved (paint mark them)?
I will check all of this and report back, Thank you!
