strange problem while driving cracking noise - VIDEO
morgre
hi guys
I have a strange problem with my Toyota
This is probably related to the traction control or mayby not
look at the VIDEO and help me to resolve it
on beginning Zero point calibration
noise you Can here many time after starting
etc TIME 2:08 or 2:22 or 3:00 and many more times
throttle down on 2:44
and it's all the time
<iframe src="//player.vimeo.com/video/78418723" width="700" height="421" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe> <p><a href="http://vimeo.com/78418723">GOPR3726</a> from <a href="http://vimeo.com/user22340205">Morgre</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
I watched the video
So the problem is that when driving along it just suddenly throttles down to 1000 RPM and you "lose power" then it returns, then repeat?
That could be a lot of different things. If you don't have a specific code to post then it will be difficult to troubleshoot via the internet. I suggest you take it to a mechanic for diagnosis. Then post he diagnosis here.
So the problem is that when driving along it just suddenly throttles down to 1000 RPM and you "lose power" then it returns, then repeat?.
This problem is sometimes. When i slow down and then try accelerate throtle going down for a while. Computer connected to diagnostic port cant read any code error.
I think this is traction control problem and cracking noise also.
Do you hear this weird noise through acceleration ?
Is it from the front or the rear? It almost sounds like abs engaging? Just a thought I would bring it to a mechanic as well.
Noise comming from the front.Yes - It sounds like abs working.
Mayby you have any solution for this ?
I live in Poland/Europę . And we don't have many 4R here.
I didn't find mechanic who can resolve it.
Mayby someone have similar problem and can give me advice how to fix this.
Thanks in advance
This may sound dumb but hows your battery? We had a Toyota Avalon come into the shop one day that would make a clicking sound after the car was turned off. Turns out because of the battery being nearly dead (car started every time). It threw off the electronics and caused them to make clicking noises.
I would try the TRAC and ABS bypass switches....they are nice to have anyhow. Then u can flip them off and see if the problem stops with one or the other. After that you would know if one of those is engaged and causing the issue. After u have it narrowed down you can focus on the issue at hand. Write ups for doing this are in the sticky section.
On a side note where did those guage faces come from?
try this, drive with the 4WD on for a few mints (push Button)
then stop and release it from 4WD and revers in straight line for about 50 feet
then see what happens:boink:.
seems very strange - but i'll try it
only ABS i think works fine -only traction try engagin it, when i put brakes i think abs works good
from whitegauges.net - but 2 small gauge - fuel and temperature - doesn't fit ty my 01' version - so i only decided to put 2 big gauges
i have new battery, installed couple months ago
i notice when terrible noise start - i release the gas pedal and noise imidiately STOPS
mayby this noise is connected with VTRAC throttle control ??
anyone have sugestion for this noise
I notice the light in the top left corner of the dash flashing.
What is that for? (Mine doesn't have it)
alsayner
