Strippted Front Diff Drain Plug Removal Tips (aka: what not to do)
Following!this seems like a very interesting thread
Here in rusty NY I put a 3ft pipe on the end of my ratchet & stood on it. It came out. I'm surprised that so many people out of the salt belt are having problems with this front diff. That was before I owned a DeWalt impact.
That's how I got [MENTION=102606]infamousRNR[/MENTION] drain plug loose. I stood with all my weight on a 2 ft breaker bar, but now I know better. Applying some heat is the way to go if it's fighting you.
i ran into the same situation on my 4runner, previous owner stripped the hex, tried the chisel method but that didn't work the first time, then i heated the case slightly with a torch and used the chisel again and that worked for me!
Just happened to us yesterday, used a torch and a punch an it came out with a few good taps. without heat it was not moving at all.
This isn't because of rust, but because the last time I had it drained and filled I had a shop do it. That was literally the last time I ever had a shop do anything to my truck (other than alignment). Because, as you can see from the pictures, they stripped the crap out of my diff drain plug with an impact. :mad:
I'd just do what we showed in the video. Get a cheap allen head socket that will fit tight into the rounded out hole of the drain plug. My buddy Ash got a very affordable allen head socket at Home Depot. Go to a muffler shop, tap the allen head socket into the plug and let some dude who knows how to weld tack it on there for you. I bet they only charge you max $20. While you are still there, make sure you can break it free. The heat from the welding will have loosened the bond and you should be able to spin off the drain plug no problem.
This will be my final option if I can't get it off with either heat & chisel, welding an allen head socket to it, or drill and pound a ratchet extension in this weekend. I have to justify the purchase of the welder somehow to the little lady :yo:
Tried once again this weekend to get this thing off with no luck :mad::mad::mad:
Also, my welding skills are below sub par, so I wasn't even able to get a nut to stick on there well enough to crank on it. Anyone have a suggestion for the settings on the HF 125AMP welder to get that nut secured on there? I tried it on low first with slow wire feed and then also on high with slow wire speed. I'm a total newb to welding and the little sticker didn't really have too much advice on this particular welding setup.
Going to try to :flamethrwoer2: the sucker this weekend and then hit it with a chisel again. If that doesn't work, then I'll use [MENTION=150857]Acorn22[/MENTION]'s method and see if I can't get a ratchet extension on there.
Not sure if you saw this thread on the same subject. Go to entry #39 and you'll see a picture of what we did with welding a sacrificial hex socket into the nut. I picked the socket up at Autozone for around $4.00. Tim is correct that heat does the trick but not everyone can be successful with a cold chisel and heat, or isn't exactly comfortable hammering that close to the transfer case. The nice thing is there are definitely options for everyone depending on comfort levels and skill sets, as well as how far along the removal attempt process one is and what became damaged in the process.
I was helping [MENTION=102606]infamousRNR[/MENTION] with some fluid changes the other day and his front diff drain bolt was of course not budging with a relatively short breaker bar, around 1 foot long. Instead of going to a larger breaker bar, I evenly heated up around the circumference of the drain plug for around 30 seconds with a butane torch and then tried again with the short breaker bar. It broke free no problem with minimal force. HEAT is definitely the answer to breaking these drain plugs free.
When you get back to Seattle, use some heat followed up with the chisel. You'll get it off. As for the welder, just tell your wife you'll build her something custom she'll like.
Also, if you notice that the drain plug isn't budging and if the Hex is not stripped you can always just tap the drain plug with a hammer (not too hard, but don't be a wimp either) to break free whatever is causing the threads to seize, then use your Hex to break the drain plug loose.
Source: Done this plenty of times on (non-rusted) front diffs in the shop.
LOL
Same thing happened to me... and with the lack of tools to deal with it, in a fit of rage I went to Toyota.
I told them DIY turned into OMG and they took care of it for $54 bucks with new parts included in the price and completed the gear oil change with my oil.
After dealing with my bruised ego I went home pretty happy, they did take care of me from a cost standpoint which was nice of them to do. I think my honesty of buggering up the thing in the first place bough me some mileage with the service writer.
LOL
My local dealer charged me $150 for the same job. Part of the reason why i started wrenching more.
I got lucky with that one… That particular service adviser knows I wrench of my own truck too, but he did help me with the dash replacement only a week before that.
I love wrenching on my own cars... but it's a fight for time these days.
In all my years of doing stuff on cars this plug is at the top of the list of stupid design choices. The other diffs have normal plugs that a socket fits on. I cannot think of any good reason for this choice. I usually put the 4Runner up on ramps so I get leverage the breaker bar. I also used a torque wrench to set torque and anti sieze and the next time was always just as bad. Would really love to meet the "engineer" that spec'd this.
I could not agree more with you. And to top it off, the replacements you buy once you mangle one up is still the same design. Toyota has to know these plugs are a serious problem but I guess it's too much trouble to redesign the plug. A regular plug that a large socket could fit on would fix this issue. But for now, I just torch those f*ckers if they are fighting me. Heat makes a huge difference. When I put the drain plug and fill plug on, I use a very mild amount of force so I don't have to kill myself getting them off the next time I'm renewing my fluid.
I did what some have suggested, welded to it. But I welded a short m10 bolt to it, tapped it in the hole, welded around. Even then it took a lot of effort to break it free. The only thing I did different then the others was use a bolt. This way you can use a wrench, or regular socket to break it free. Or loosen it. I put mine back in, welded on bolt and all. To my mind, I improved the system. I want it to be able to get it out next time too.
I was able to get mine with a sharpened cold chisel and an 8lb sledge. If you get the chisel really sunk into the edge you can get some pretty good rotational force out of it without it slipping. I'm sure heat would also help but in my case I didn't need it
If somebody wants to source cheap drain plugs and what bolt they want welded to it I would weld ~20 of them for free, just pay postage.
What works for me is HEAT. I could feel the hex socket start to strip out so, so I tried the chissel on the edgde and still no movement.
Finally I used my plumbers propane torch to heat the drain plug until it smoked. Then with a hex key in my ratchet wrench, it broke free. Dont make it cherry red, heat it just until its hot enough to smoke. Heat breaks the bond between dissimilar metals at the seat, ie. the steel plug and aluminum washer. The diff pumpkni is a heat sink so the heat on the threads wont get hot enough to set the diff oil on fire so dont freak out.
Yeah, when I did mine I went to heat as soon as I felt how tight that plug was. Took a couple of tries but no damage done.
:dammit: As previously stated, I suck at welding. Couldn't get this thing to stick to the plug, though it seems that it is welding to the hex socket just fine. The heat from welding didn't seem to help it budge neither, nor did giving it some whacks to try and loosen it up. Next try I'm going to try the hex extractors that [MENTION=44978]kball[/MENTION] mentioned.
Got this kit from Amazon for $40 that has the full assortment of extractors from 1/8" to 7/8":
Initially, I was going to try to drill out the drain plug some more and tap in the 15/32" sized extractor, but I can't fit that sized drill bit in my 3/8" drill. Need a 1/2" chuck drill in the future. I was able to tap the 7/16" sized extractor into the stripped out hole just fine, though I was worried it would just spin. It went in okay and seemed to bite:
Started cranking on it and was afraid I was going to break the extractor. The previous one I used snapped in two, as you can see from the original post. After trying a breaker bar, and then my long extendable rachet, there was a pop!!
:banana: :reddance: :party:
I'm glad to have finally gotten this stupid plug out of there, as there was a bunch of fine metal all over the magnet. Time to regear :biggrin2:
Thank you everyone for all the tips!! Ultimately, the whole issue could have been prevented if the place I had previously had the diff drained and refilled at had used the copper drain washer. That last picture is how it came out of the diff; NO WASHER WTF!!!
So, after all this trouble getting the old stripped out drain plug and putting a new one in, torquing it to the proper 48 ft/lbs, and using the copper washer and all; Went to drain the front diff again last weekend and it was stuck again. Once again it was stuck enough that it ended up getting stripped again to where only the Irwin extractor would get the thing out (loves those extractors though!).
So, put another drain plug on order at the local Toyota dealership, but it got me wondering: is there a better solution that I'm missing here? I've read in a couple different spots now that have said the drain plug part number was updated so it now has a 12mm hex on it versus the original 10mm. The one I replaced it with was 10mm, though I got that off of Amazon. Hoping the dealership has one of these supposed upgraded drain plugs with the larger hex.
Grrrrrrr
seltzernator
