Stuck in park pos...
jeffmsunvalley
Truck starts fine but I cant get it out of parking position. Just had to replace the positive battery terminal. any suggestions on what this may be. I was thinking the Neutral safety switch. Hoping its something simple. please help. Thanks...
No idea but there is a way to bypass it, there if a plastic piece you remove infront if your shifter. After thats removed push the button down and you should be able to shift.
is your foot on the break peddle?
Had the same issue, check your fuses.
Deelock
