Suggestion for Better than OEM or LED Information Center Bulb?
JoshuaHufford
I just bought a 2007 T4R and the information center bulbs are burnt out.
Are there any aftermarket bulb for these? Perhaps LED? I don't want to change all of my dash lights, not up for taking the whole thing apart, but I do want to fix these so I can see the display at night.
I just ordered a couple from here per some other members recommendation
Neo Wedge
haven't arrived yet but there are also some OEM style ones on amazon as well that have good reviews.
Detailed write-ups on the forum as well from guys who have done just a few to full dash swaps.
Neo Wedge
I don't want to spend $6 each for the oem replacement bulbs.
Looking at purchasing the bulbs from the link you shared!
If I was to buy, which pack would I buy? Any advice?
Neo Wedge
Which bulb sizes did you order for the clock lights and the AC lights?
T4
The sizes go off the base diameter of the insert and the overall height of the bulb. I used a caliper and just ordered what I thought was correct.
That being said, I went for the stock look and ordered the T4 - Amber. (might be white and the lcd is amber but we'll find out..lol) It says 2pcs/order so I'm hoping that is two actual bulbs and not just the bulb and the insert. It has been about two weeks since I ordered so I'm hoping they show soon.
Any response or received parts from Neo Wedge? I ordered parts from them but have not received any response
Took a full 3 weeks for me. Seller is out of HongKong I guess but responded to my email promptly. Housings seemed slightly undersized on the OD and overall of cheaper quality. (Expected for the $, but I didn't even bother testing fit)
However, the LED is removable if you gently break away the adhesive. I pulled it out, sanded down the top slighty (the resistor makes it stick out from the housing) and reinstalled with the factory inserts. Everything is back working correctly again so no real complaints.
