Suggestions: HID conversion kits (PURE WHITE)
So...its just plug and play on the 3rd gens? All you have to do is remove the light bulb and plug in the new one? :cheers: I should have done this years ago. Please confirm my assumptions
Not exactly. You will remove both light bulbs then put in the new HID light bulbs. Then you will need to find a good place to mount the ballasts that is close to the light bulbs. After that you run a power wire from your positive battery terminal to the ballasts. To finish it off you need to ground the ballasts.
It's pretty simple. Probably sounds harder than it is.
Thanks...I did some reading on the site and came to the same conclusion..thanks for the info btw.
