Sunroof Issue - 2014
Miguelon
2014 Unlimited
There are two switches on the sunroof. One for slide and one for tilt. I noticed that if I hold it down, the tilt switch will also slide. Also the same is true for the slide switch ..if I hold it down, it will slide and tilt. Essentially, I have two switches that both carry dual functionality.
Any one else with this issue?
2014 Unlimited
Mine works perfectly. One switch says Slide and the other switch says Up and Down.
I believe you're going through the initialization process for the pinch protection on the sunroof. If you hold it it should go through every motion so it learns where and when to stop.
