Supercharger installation questions
4restGump
Hello all
I’m in the process of wrapping up a trd supercharger installation on my 2000 limited.
The sc came of 2004 Tacoma 5 speed. The kit came with everything including the URD 7h injector kit. On the Tacoma it’s running 5psi. I would assume it’ll run the same in my 4r. The part that got me puzzle is does it matter that my 4r is AT and the donor truck is 5speed?
Also will the installation of the URD kit the same?
Anyone have a URD 7th injector installation guide would be really appreciated. TIA
First, get the mechanical side sorted out. Make sure you have the right throttle cable bracket for your truck (needs to have the trans kick down cable attachment). Your truck will run fine without the 7th injector kit for a bit, especially if you are running the stock pulley.
Then figure out the 7th injector wiring...
-Charlie
Thank you for the reminder of the kick down bracket. I was able to make a bracket out of a 90 degree bend.
I’ve also got luck out from the donor truck. The URD unit actually came with the harness so I was able to plug-n-play.
The truck is up and running this afternoon.
peacefulpiranha
