Supra725 Build Thread
So here is an little update..
End of the month, there will be something added to my rig; the sliders are going on the rig, pictures will follow after it is installed.... And hopefully next month, I will save up enough money for the duratracs's.
After that, is going to be maintance for it..
Has anyone used this kit?
Toyota 3.4L/V6 Complete Timing Belt & Water Pump Kit | eBay
If so, how as it? If not, what other kits would you guys recommend for the timing belt and all it's bells and whistles..
Another thing is valve cover gasket has started to leak a little. Figure after 260k miles.. Is alright that is seeping a little out..
My question is, which gasket should I replace it with? Cause I probably be doing it along with the timing belt change..
from this weekend's meet
IMG_4738.jpg~original
IMG_4740.jpg~original
IMG_4745.jpg~original
IMG_4746.jpg~original
IMG_4748.jpg~original
IMG_4751.jpg~original
and there is an surprise this weekend
little update..
current..
IMG_3707.jpg~original
but after this weekend something will be missing but something will be added..
hint: it sticks on something long..
CIMG3121.jpg~original
Can you list the steps it took to paint your rims flat black. I'm trying to do the same thing and I don't want to mess up. Thank you :)
Did I miss something?
I thought this was called "Supra725 Build Thread"!
I'm not sure what a Supra 725 is but I wanted to see it.
Your not the only one man I thought I was going to see a big turbo 2-jz in a monster trail rig lol!!
Wheels look great man so do the retros those are a pain to get lined up just right
thanks everyone..
hopefully next month or September.. the new tires are going on..
after that.. it probably be maintenance till the end of the year..
knoxrocks222.
the retros is not that bad lining up.. when I put it in... it was pretty level..
next week.. there will be an surprise..
went down to the local shop and ordered 4 ______
A. Shocks
B. Wheels
C. Tires.
so upon doing my research on the new tires..
with the E rated Duratrac's, you gain an additional 2/32 treads.. should I opt out for the E rated? or should I stick with C rated?
thanks.
freddygino
