suspension diagram????anyoene have it?
beliy25
hi all,i am looking to find a suspension diagram for front and back with part names !!!
can anyone help me with that?i tried google,they have pictures of it but no names to the part,they are only numbered but there is no glossary to those numbers!!!
i have recently changed all 4 stock shocks for 5100s,it seemed fine in the beginning until now,i started to have strange sound coming from either back or front wheels when i hit even little bumps and holes.the sound is similar to when i had stock shocks.also i did an allignment and the car pulls to the right when i brake.i just want to change all or most parts which concerns suspension on the front.
i have 2006 v8 sport with 1.5 spacers and moog springs with 5100s all around.
front is lifted all the way with 5100s.
dont tow or off road but need to tow 3 motorcycles in may so i want to be confident ill be able to do so...
thanks a lot for help
ILya
ILya
Sounds like how mine acted when my brake calipers went bad. take tires off, have someone pump brakes with car off as you watch each piston on the calipers to make sure they are all moving. The inside ones especially tend to freeze up. Also check rotors and pads while tires are off.
right caliper is new,left caliper is working fine,checked 3weeks ago.!!!
i am concened about alignment and the sound when i hit the bump like something is loose and is banging against something is what scares me.
Someone posted a front suspension diagram on here from the Toyota Service Manual...but I can't find it now? Sorry to here about your problem...I have a Toy Tec 3" Spacer Lift in front with the factory shocks still installed and the Taller Toy Tec 3" Springs in back...A shop did the Alignment and I have never had any trouble like you describe. Now I am replacing the front shocks and spacers with the Bilstein 5100 Adjustable shocks and Bilstein's in back. I am setting the snap ring to the 2" position on the front shocks because the replacement Springs (MOOG p/n 81090) are 1" Taller than factory. I want to maintain my 3" lift up front...I saved that diagram in my Favorites but it won't let me send it anywhere...
OK- Here is the Link for the Front & Back Suspension...Toyota 4 Runner.
"app.box.com/shared/p2rsns9zb6/1/56101336/541860546/1"...Just copy and paste to Google Search...Hope this helps!
charlesz
