Swapping rear springs
Jester4kicks
So I got my new Toytec superflex coils to replace my OME 895's and soften the ride up bit.
I was hoping to be able to install them by myself, but I'm running into a hitch... I can't seem to get the shock off the lower mounting point, and I really don't want to have to loosen and re-tighten the top nut on it.
Should I be able to get the shock off and back on that bottom post without removing the nut at the top? So far, I've only been able to pry it about 20% of the way. The bushing on there is really tough, and it doesn't seem like the angle will allow it to come straight off.
Thoughts?
I've swapped the rear springs before without in bolting the top nut on the shock. I think you should be ok without having to do that. Definitely in bolt the sway bar!! I forgot one time on my 3rd gen and pulled the nut thru the washers... Good luck!
Thoughts?
I just did my rear lift this weekend. The axel stud did seem to be at an angle that required a mallet to help it back on. Like the other post said, try unbolting your top link arm bolts. I took mine off with the wheels jacked up under the diff. I believe there is some tension/pressure there. That bushing and stud are both metal, maybe some penetrating oil would help too. Keep us posted. Best regards, Doug
Thanks for the encouragement!
I just finished the job 5 mins ago. The persuader was the ticket, along with some pb blaster.
The height looks about the same as it did with the OME 895's. I'll make a judgement about the ride once things have a chance to settle in.
The only other lesson learned was regarding installing the new springs. The toytec's are a bit taller than the OME's (pic below). I had already disconnected the rear sway bar, but to get them in, I had to let the rear axle hang AND use the stock jack between the axle and bumpstop to push the axle down.
Once they were in, everything else went like a charm!
Thanks again!
IMAG0346-1.jpg~original
IMAG0345-1.jpg~original
Well I just drove into the office and back, and it sure feels a lot more comfortable!
Even if my mind was playing tricks on me, there was a definite decrease in the number of rattles and vibration noises that I normally hear on the way to work.
It should only get better as the springs settle. I'll let you know if anything changes for the worse.
Good to hear, thanks. I think this will be my post-Thanksgiving project now. Probably order one of those OME 10mm rear spacers to try and fix the driver-side lean as well while I'm at it.
