Swapping SR5 stock tires to TRD rims, silly question
you may need to remove the front mud flaps, however I'm curious as to why you would use 255's. A lot of snowy roads?
I have heard great results from that size. Yes, I have snowy roads, and yes it slightly narrower (1/2"), but again I think they'll fit the vehicle perfectly. The size is lighter, is a 32" tire, and from what I have read makes the vehicle perform well under most circumstances. It has been a long debate between these and 275's. I have come to the conclusion that the lighter and narrow tire will perform well for my intended purposes.
I was contemplating 275/70/17 Wildpeaks at 57 lbs. or 255/75/17 at 39 lbs. a tire. Both 32"s
The 255's with a light wheel will probably make the car perform better in most situations save for deep mud or rock crawling. Also may improve city MPG.
For fun, try to convince me otherwise... I am open minded.
FYI, those are not OEM. OEM is 7” wide not 8”, also are matte. Might be a kncockoff. Only “copy” I would use is the FN brand personally.
I thought because they are advertised as Toyota OEM that they are legit. They have great reseller ratings. It may just be a typo. If not they are shady for advertising
Toyota OEM.
Toyota OEM.
Those are definitely not OEM. They are reproductions and not very good ones. Look closely at the spokes and center caps. You can get OEM ones shipped for less than $100 more.
My 2018 SR5 stock tires have just under 8k miles on them. I want to purchase the TRD rims as there is a sale right now online where i can get them for $161 a piece plus shipping
The thing is I do not want to spend money on new tires right now. I've heard mixed opinions on swapping tires. I would think since these are relatively new tires it wouldn't be an issue with swapping and i believe the rims are the same exact size, right?
Are there any issues i should be aware of? Is it just a simple swap?
Thanks in advance for your input! happy friday!
It’s a simple swap ,did the same. Sr5 wheels I sold for $400 or so and bought the trd pro wheels at 650 or so . It’s purely cosmetic look though , I would prefer an aftermarket wider wheel but happy with it overall and cost wasn’t bad
Well, i pulled the trigger and ordered em. I think the sale ends 4/1(although i bet there will be another eventually).
I'm sure they will look funny on stock tires, but i like that I'm pushing things in the right direction to get the look i want. Between the wheels, the cargo box and the chinese grill, i'm already headed down a rabbit hole with upgrades/mods/changes aren't I? I'm excited about it though as I don't usually do this kind of stuff.
How feasible would it be for me to get $100/wheel? It's SR5 wheels with minor scuffs and scratches from when the dealer re-balanced my tires many many times.
Should fit fine here’s mine on SR5 4wd with XP Predator package....and mine came matte black, shows no dirt or brake dust
Possible tire rub with swap
I am also considering swapping from stock SR5 whees to the TRDs. Both are 7" wide, but the offest is different (more negative on the TRDs). It seems that many people have made the swap without problems. At least one owner apparently got rubbing--perhaps the tire size or brand of tire they used was just enough bigger to catch a corner of tread. In any case, there is the real possibility that the change in offset might change the tire position enough to make rubbing a risk with the TRD wheels but not with the stock wheels.
Has anybody put 275/70/17 KO2s with TRD wheels on an SR5? If so, any rubbing?
