switch to right side of steering wheel
anyone with a DrKDSS switch put it here?
That's where I put mine, actually. It's a PITA to get the switch blank out - access is super limited without tearing everything apart. I ended up drilling a hole through the blank and using a pick to unclip it and pull it out and then fished my wires up and pressed in the new switch.
As annoying as it was to install in that location, I think it's the best place for it. Because it's the only switch in that location, I can hit it on the fly and not worry about turning on something else.
Party Mode button, if you don't have it I hope Toyota set up the audio in subsequent years to always be in a party mode like setting or configuration. Sounds so much better with party mode on vs. off.
On my to do list! Thanks for heads up on PITA.
