T4rchadly's "RADRNR" build thread (IFS wannabe rock crawler on 37s)
yep ill be showing how i did everything with the headlights including the end outcome, beam pattern etc.
im probably going to end up riding this 3.4 until it grenades. i just barely bought a spare block im going to be doing new bearings and rings on along with some ARP studs and MLS head gasket for the turbo setup i want to do. if it blows before this happens, itll just hang tight in the garage for awhile until other engine is done
What do you think of the LCE heavy flywheel? Would you do it again?
nothing too special, but i got this yakima space booster on that i just purchased. its a lot smaller than my skybox 18 i had for awhile on my other sherpa rack, which is what i wanted after having a big one i realized i dont have enough stuff to fill an 18. this 11 should be perfect for all the skiing and bike trips i do
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51857113981/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51857113981_1a7e29047a_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script><a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51856157057/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51856157057_dc700a063b_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
That's basically the same roof box I have - It had too much rear overhang with the stock cross bars, so I can actually install it on the 4Runner now. You can still fit 2 bikes or another ski/board carrier on the other side:
-Charlie
more lists
im motivated by crossing out lists. so; heres yet another list i am making so i can get the truck wheelable for march
-rear arb rebuild (doesn't even engage anymore) - ring gear hit copper line. - done w/ new pinon seal
-steering rack
-oil change - done
-OTR's??? need to check - done; no need for OTR
-passenger side diff seal (the fronts... leaking.. again..:smow::frusty:)
-rear upper control arms - done
-headlights - done
-adjust clutch - done
-fix the stupid broken piece right behind sunroof. it rattles - done
-re torque front spacers - done
-finish decking for firewood + maxtrax
- air filter - done
bad news bears
i got almost all the maintence dont other than the steering rack and upper links done. i knew i was going to get the short end of the stick with my ARB differential before pulling it, but i took the risk of only buying new seals as this has happened twice now. i took the differential out and found something slightly wrong.... :frusty:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51882857169/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51882857169_228c96546b_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
the ring gear took the copper line out.. i ordered a new lock sealing ring kit and waiting for that to come in so i can rebuild the locker unit... that it all
p.s. 5 lug nuts were loose on the wheel spacers. remember to check your wheel spacers
Your truck is as much of a constant project as mine it would seem haha! Rack looks great! Steering rack that is...
its never ending..... the steering rack makes an absurd pop now when i turn when stationary:cell: the inner tie rod is also very bent on the driver side and i keep aligning it and it keeps bending haha rather than spending almost $400 after shipping/taxes on ITR's i am more than happy to spend 500 with a brand new rack included:crutch:
the one where i can see, and the one where i am locked again
been doing a lot of hard progress on the 4runner lately. ive had this absolute abnoxious sound in the bac of my 4runner that ive replaced a lot of things trying to fix but no luck. i replaced upper links for the back but nothing has changed. i think its a blown up body mount at this point, or something that has to do with the sleeping platform for whatever reason. it is an odd noise. issue is TBD
i also FINALLY got my rear arb differential fixed and i finally have lockers again. since i blew up the copper line, i had to replace the sealing ring mechanism. this is what i had to do after i took the diff out.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892366899/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892366899_53f1b6eca5_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51891068852/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51891068852_3720d5667f_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892026471/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892026471_ab86caaca2_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892681020/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892681020_d8cf8c566e_b.jpg" width="768" height="1024" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51891069002/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51891069002_e3bfab5061_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892681160/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892681160_1aeeec7216_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
the job was intimidating at first because ive never really torn apart differentials but it ended up being a really cool learning experience and didnt take as long as i thought. the pinion is also leaking so i replaced with a new oem pinion seal. locker works as should now!
update pictures on these headlights i mentioned awhile back. expecting to have them running this week
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892114628/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892114628_495c33a76e_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892114373/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892114373_70a853c4e0_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892681045/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892681045_6ab40ee718_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51891069012/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51891069012_1a0c3eaa2a_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
and lastly, with the lenses on, this is my low beam pattern with both sides running. the tape line is my projector cutoff line form the nomad headlights
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892680965/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892680965_4306a22313_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51892026186/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51892026186_83cabcaece_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
the next things i want to tackle is new steering rack, and getting my second engine in the truck. i plan on turboing so i will keep the old engine specifically for mock up
Your take on headlight retrofit looks pretty awesome! Any ideas on the legality of the lights you are using for it? (I'm not trying to start a debate here in your comment section, just curious if the lights are DOT certified and if you think they might be a potential problem with law enforcement.)
thanks! with that being said
extremely illegal. i dont think ill have issue though with how the beam is pointed with the cutoff line. we will see and i will post if i do get a ticket
and finally... completion
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51901348920/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51901348920_bc0b2ecf12_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51901349015/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51901349015_602303804c_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51901024404/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51901024404_6e3447da41_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51899734437/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51899734437_a377d8e5be_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
finally got everything working as should. i was having issues with the headlights not working on the headlight connector. i got an h4 connector to plug in, and put grounds together, lo to blue and hi to red. nothing would work, but when i bench test everything works.. the wiring ended up being like this. i will make a youtube video soon when i do a secon pair, this is the schematic i drew up for you guys really quick
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51899779867/in/dateposted-public/" title="Edit Type Layer"><img src="https://live.staticflickr.com/65535/51899779867_0986de6d12_b.jpg" width="1024" height="512" alt="Edit Type Layer"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
this is the link to the male h4 connector i used
Amazon.com: TOMALL H4 HB2 9003 Male Socket for LED Replacement Headlight Connector Wiring Harness Conversion Kit : Automotive
after running looming
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51901024264/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51901024264_804c3fbafb_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51901024219/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51901024219_03459328d4_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51901024004/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51901024004_2527883ffc_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
i also installed a more heavy duty pressure switch for my ARB compressor. the stock pressure switch shuts off at 70psi and is prone to damage your locker possibly over time due to not enough pressure to move the collar. this 120psi pressure switch will ensure to use pressure needed without damage or fatigue over time.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/51900693856/in/dateposted-public/" title="Untitled"><img src="https://live.staticflickr.com/65535/51900693856_e0aff4440e_b.jpg" width="1024" height="768" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Pressure Switch 120-150 PSI Air Compressor Pressure Switch 1/4"-18 NPT Air Pessure Switch 24V 12V Pressure Switch Air Tank High 150PSI Pressure Switch 120PSI Pressure Controller - - Amazon.com
Looks awesome man, great work! Interested to see how you like them and if you get into trouble
Your new headlight setup looks sick, but didn't you have retrofits? Why did you change? I'm trying to do retrofits but if that is better lighting I'd be tempted (at my own risk lol) to do the same.
yeah i had G2 bx built LED projectors on a build me and will did. there was nothing wrong other than the headlight broke again (housing) and if i was going to have to build ANOTHER headlight i wanted to try n have some fun is all. the projector has better hot spots i feel like. its never bad to experiment IMO as long as your experiments arent ghetto lol well see how long i have these for
The new headlights came out awesome Chad! You made the wiring look easier than I would've expected. Are you happy with the output?
so far i am pleased, although i thought there would be a little bit more of a hot spot on both hi and low beams. i need more time as i only drive the truck once a week or so, i need more time using them to have a full opinion
Gonzaga Lobos
