T4Rchadly
Member
I can't find the name outbound_nevada on the search function. Do you have any other way of contacting him about his mod panels?
OUTBOUND NEVADA RIGS & RACKS (@outbound_nevada) • Instagram photos and videos
Security Check Required
well i found out the shop had bent a 2 tabs and THEY stripped out my eccentric tabs. i called them and they were comprabe. My neighbor currently in bountiful, Utah runs 333 fabrications and recently came out with a "eccenntric eliminator" and i decided instead of running a new eccentric, ill use his new product. becuase it is a square, you can see that it only has 3 different specs to change from vs fine tuning. (positive, neutral, negative) this eliminated the changes of eccentric moving after wheeling and screwing your allignment up. it is suppose to stay the exact same unless you bed the tabs.. oh yeah about that. i go back to the shop and said i wont create a huge fuss and get reimburcements, etc etc if they were to just bend back the tabs that they bent, weld them so they dont bent back, and install these new tabs without charging me, and of course unscrewing their allignment they did. they were cool with that. this is the outcome of all that.
they told me they had camber issues and had to go to setting E is what i believe they said? they told me if it has ANY rubbing or if it drives shitty on the highway to bring it back and theyll redo it. allignment geeks andy input on the caster job? it drives alright i guess from the slight highway driving and city driving on the way home. well see if it rubs when i go wheeling.
Interesting..
I currently have BuiltRight Uniball UCAs that i'm considering turning into heim joint UCAs. I'm tired of having my alignment knocked out every time offroading so I'm planning on doing the 333 tabs with TC cam tab gussets.
I'm considering swapping out to SPC UCAs as well, so I'm interested to hear your thoughts on how the truck drives and etc. before doing this. Objectively probably cheaper for me to modify my UCAs as well. Why do you have such little caster?
i mean i guess it drives pretty good but i was wondering the same thing with the caster. if i rub i think im going to have them try putting the camber setting at neutral and back to setting G? i was trying to figure out why the caster is so little as well. elijah lund who is one of the big dogs for 333 has a caster of around 3.0 i think but hes on crazy long arm stuff.. the install was super smooth and painless (the SPC's). took me about 40 minutes for both sides torqued back to spec. they seem like they will do me well. im going to MOAB tomorrow so well see how the 3 1/2 highway trip feels with the new allignment and see if i rub when i go wheeling. i will post updates on both moab and ANOTHER allignment sheet if i get another one.
I mean from the SPC spec sheet running G is going to give you even worse caster. That 4Runner must want to wander all over the road or its closing on the verge to do so. Why are you so concerned with having it set on G? You shouldn't be rubbing that badly to begin with on 285s (possibly at full lock). Proper back spaced wheels help the most.
https://www.spcalignment.com/instructions/25460_xAxis-INS_WEB.pdf
(SPC has two different pdfs for different bushings but the ball joint is the same)
nope doesn't wander. but like i said i only drove 20 miles home. yes going to G will create less caster but putting the camber plates to neutral should give me more caster without pulling it back too far (reccomended by my neighbor). my goal is to not touch pinchweld with these TRD pro wheels for when i go to 35's i tub the least amount possible (unwilling to run a bodylift, and to get a set of aftermarket wheels unless nice method beadlocks or trailready beadlocks) heres also a thread to consider if you havent seen this one already!
SPC UCA Alignment Sheets
It still has a bit positive caster so it shouldn't but definitely should have more than that. Steering wheel might feel a bit loose though.
Not sure why this forum is so against body lifts. They do a lot as far as adding suspension up travel and minimizing the amount of rubbing / tubbing for bigger tires. Weld new mounting points on your bumpers if you're worried about a body gap.
Nice idea on the DIY bike rack. Following that for sure. Check This Link out of a group buy that just happened on TacomaWorld. Maybe it can give you a few ideas. Looks pretty similar to what you're trying to accomplish.
Also, how are you liking those Vision X Light Cannons? I picked up three on a deal not too long ago, I just need to remove my current HIDs and put these in their place. Hoping they'll do the trick as far as spot light power goes.
My old spots are some old ANZO 4" HIDs so I'm sure these will be a massive improvement. I got them on a deal that was too good to pass up so figured why not. I'll have to check out the different covers as well.thanks for that link! i may try to copy a comonent he did on it..
as for the vision X light cannons, i really like them. its cool that they offer covers that are different color for different situations, and different beam patterns. i have the 10º beam pattern so its not very wide but wow are the hot spots bright.. since they are a bit older technology im really interested in trying some BD LP6's. this will be later down the road and have other stuff id like to get done first.
I'll be envious of those BD LP6s when you do decide on them. I've heard nothing but great things about them. I was actually looking at them until the deal popped up on the Vison X's and I figured these would suffice for now.
Anyways, sub'd to see where this build takes you. Looks like there's some solid travels to come.
