TC UCA Question
tigger
To those of you with TC UCAs, what did you do with the sensor line bracket? DId you remove it and zip tie the line directly to the UCA, or did you somehow attach the bracket to the UCA?
THanks,
Brian
I removed the bracket and zip tied the wire to the arm. There was a tab that worked perfect for zip tying to on the arm.
THanks,
Brian
I have installed these on someone else's ride before. If I remember correctly, the bracket will fit through the stud on the arm and then you tighten it down with the new provided nut.
EDIT:
My bad, according to the instructions, http://www.chaosfab.com/PDF/install/96504.pdf
that doesn't exist. I must be thinking of the Icon tubular arms. Sounds like removing the bracket and zip tying is the best option.
Remove the bracket and zip tie, but be careful. A few people on this forum have damaged the wire when installing lifts and I wouldn't be surprised if this is how they did it.
I just installed my TC UCA's yesterday. I zipped tied mine to the tab on the UCA with the provided zip ties. Without some type of fabrication/modification, I don't see an easy way to use the factory bracket.
DionicioLives
