TE Parts Needed to Convert SR5/Limited Exterior
harper7
Senior Member
TE Parts Needed to Convert SR5/Limited Exterior 2010-13
A bunch of people have asked me for the Trail Edition exterior part numbers that I used to convert the look of my Limited.
Finally got around to semi-organizing most of them. This can also be handy if someone with a Trail Ed. needs to replace something do to trail damage. The front and rear bumper covers will have to be painted body color of course,they come in black ABS plastic. I got the online prices for the parts from...ToyotaPartSales.com
You might find cheaper prices elsewhere?
I painted some exterior parts satin black with satin clearcoat like the door handles,fog light surrounds,front and rear Toyota emblems and their bases(aka wings).
Also,some exterior parts like the mirrors,headlights,hood and taillights I didn't change out and are different on the TE.
Here is a pic and corresponding part numbers.
<a href="http://s420.photobucket.com/albums/pp282/gharper60/?action=view&current=CopyofPicture018.jpg" target="_blank"><img src="http://i420.photobucket.com/albums/pp282/gharper60/CopyofPicture018.jpg" border="0" alt="Photobucket"></a>
PARTS to Convert SR5/Limited Ext. to Trail Edition
• --------Part Name----- OEM Part #--- msrp - online cost
• A.)Front Valence Panel 53901-35210 $143.52 -104.99
• B.) Front Bumper Cover 52119-35907 $246.01 -177.42...reported to have changed to 52119-35910
• C.) R. Rear Bumper Support 52155-35040 $40.53 – 29.23
• D.) L. Rear Bumper Support 52156-35040 $40.53 – 29.23
• E.) R. Rear Bumper Bracket 53723-35030 $65.82 – 47.48
• F.) L. Rear Bumper Bracket 53724-35020 $65.83 – 47.48
• G.) R. Rear Corner Flare 75653-35120 $46.07 – 33.24
• H.) L. Rear Corner Flare 75654-35120 $46.07 – 33.24
• I.) R. Rear Bumper Flare 52707-35010 $54.33 – 39.19
• J.) L. Rear Bumper Flare 52706-35010 $54.33 – 39.19
• K.) R.Rear Door Moulding(flare) 75741-35150 $67.19 – 48.47
• L.) L.Rear Door Moulding(flare) 75742-35150 $67.19 – 48.47
• M.) L. Rear Mudflap 76608-35110 $42.87 – 30.92
• N.) R. Rear Mudflap 76607-35110 $42.87 – 30.92
• O.) R. Rocker Moulding 75806-35100 $224.46- 161.94
• P.) L. Rocker Moulding 75805-35130 $224.46 –161.94
• Q.) R. Front Fender Flare 53847-35140 $142.70 –102.95
• R.) L. Front Fender Flare 53848-35140 $142.70 –102.95
• S.) L. Front Bumper Support 52116-35130 $37.75 – 27.24
• T.) R. Front Bumper Support 52115-35140 $37.75 – 27.24
• U.) L. Inner Fender Liner 53876-35120 $82.45 – 59.48
• V.) R. Inner Fender Liner 53875-35130 $87.63 – 63.22
• W.) R. Front Mudflap 76603-35050 $42.87 – 30.92
• X.) L. Front Mudflap 76604-35050 $42.87 – 30.92
• Y.) Rear Bumper Lower Cover 52169-35080 $123.66- 89.22
• Z.) Rear Bumper Cover 52159-35915 $277.64-200.30
* not seen in pic because they are already installed on Front Bumper Cover
*R. Front Bumper Cover Flare 52112-35150 $64.30 – 46.38
* L. Front Bumper Cover Flare 52113-35140 $64.30 – 46.38
-------------------------TOTAL--------------------------$1890.55
• ** You will also need the outer dust seals,retainers and fasteners for the rear passenger doors.
• I don’t have them on mine yet so not sure of the part numbers.They are not really needed as there are inner rubber seals too. I will update when I go the parts dept and find out/order them.
• *** I don’t have the amount of plastic fasteners used as I reused a lot of mine and they
• ordered the rest. I do know you need a lot of 75392-35200 blue fasteners(at least 25,they call them retainers)
• and some 52535-0E030 retainers for the front valence.
You will have to ask your local parts dept for numbers and types of these plastic fasteners.
Please don't ask "how to do it" because I don't know how to answer that. I just did it from experience and if you have experience with body work it should'nt be a problem.It should be in the repair and collision repair manuals posted in the forum. If not sure if you can do it,print this out and take it to a body shop or have me do it for a nominal charge.
A couple of the R. for Right(passengers side) and L. for left(Drivers side) might be mixed up.Double check if your ordering just one side.If you find any errors or have questions ,PM me!Took me awhile to organize this but I did the best I could.
I have this online in my Google Docs in a word document if you want to download and print this here.... https://docs0.google.com/document/e...XR88HBEnD5_CthXEwsPJs&hl=en&authkey=CKK8_eoE#
Good Luck:cheers:
Here are some pics of the parts and the install.....Picasa Web Albums - harper7 - TE exterior C...
Reply to SeattleMike
..... he's correct,the disassembly/assembly should all be in the repair or collision manuals posted here on the forum.
Also,as he mentioned, pretty sure the 4cyl front bumper cover(OEM Part Number 52119-35905) is the same as the TE(Part B) but doesn't have the slots and holes cut in it for attachment of the front valance(Part A).
How about the smoked headlights and tail lights? Any part #'s and/or prices for those? Thanks!
They aren't actually smoked .The inside part that is chrome on the SR5/Limited lights is black on the TE lights is all. As Jesse said, the fronts can be separated and painted black. The rears can not be separated as far as I could tell, and I tried.
You can get some VHT nightshade spray on tint or vinyl wrap and then you can "smoke em if you got em"
2010 TE Headlights
R 81130-35530 ~$179 with a $249.19msrp
L 81170-35530 ~$179 -- $249.19
2010 TE Tail Lamps
R 81551-35370 ~$178 -- $244.83
L 81561-35370 ~$178 -- $244.83
First price is from Toyotapartsales dot com
Hopefully, the gremlin wasn't a required addition for the conversion. ;):
Gremlin?That's the required Gargoyle and he watchs over all the work....lol
Bought him over in the Netherlands celebrating Koninginnedag long ago!:beer:
WHOOHooooo It ain't much if it ain't Dutch! :trophy:
plus only us Dutchies can legitimately say we can stick our finger in a dike without P.C. repercussions! LMAO :biggrin2:
Okki
Rocker Moulding
Has anybody come out with an aftermarket SR5 specific Rocker Moulding that is is shaped like the TE so that you don't have to replace the trim all the way around? Seems like a simple concept.
If you are needing them to install sliders, just cut your SR5 rockers. Very simple and then you dont have to buy anything :)
Harper,
Can you tell me what the minimum number of parts to replace are? I have the limited with the shrockworks sliders. I want the cleaner look of the TE parts as opposed to trimming the original limited pieces. I have a connection with a great painter and my desire is to order just the pieces that I need and have them painted to natch the silver. Do I need to replace the fender flares and the rocker panel or will the TE rocker fit into the existing limited flares?
Thanks,
Chris
Harper,
Thanks,
Chris
Hey Chris,
Minimum number of parts......For just doing the sides,they won't match up perfect, but still looks good as I think you are wanting to do what Okkie did here.....http://www.toyota-4runner.org/5th-gen-t4rs/94578-okkis-build-thread.html#post831782
If your going to do the front and rear bumper covers,it takes alot of parts as the inner wheel well liners are different and have to be changed too.
Let me know if that's what your wanting to know.
Thanks! That should do the trick. It minimizes the number of parts and covers up the unfinished areas. I mainly want the protections before the salt and slush of the winter.
does anyone know if i can just put the trail front bumper on my sr5 instead of buying all those parts? I know the side are matte black but i can just paint that part to match. thanks any info will help
no, the panels don't match up. check out harper's build thread.
You could do some of the parts but things will be off a little. harper7 can clear it up better--just read through his build thread first though.
Parts paint up just fine. :hatsoff:
TEPartsPainted3.jpg~original
TEPartsPainted2.jpg~original
TEPartsPainted1.jpg~original
