harper7
Senior Member
TE Parts Needed to Convert SR5/Limited Exterior 2010-13
A bunch of people have asked me for the Trail Edition exterior part numbers that I used to convert the look of my Limited.
Finally got around to semi-organizing most of them. This can also be handy if someone with a Trail Ed. needs to replace something do to trail damage. The front and rear bumper covers will have to be painted body color of course,they come in black ABS plastic. I got the online prices for the parts from...ToyotaPartSales.com
You might find cheaper prices elsewhere?
I painted some exterior parts satin black with satin clearcoat like the door handles,fog light surrounds,front and rear Toyota emblems and their bases(aka wings).
Also,some exterior parts like the mirrors,headlights,hood and taillights I didn't change out and are different on the TE.
Here is a pic and corresponding part numbers.
<a href="http://s420.photobucket.com/albums/pp282/gharper60/?action=view¤t=CopyofPicture018.jpg" target="_blank"><img src="http://i420.photobucket.com/albums/pp282/gharper60/CopyofPicture018.jpg" border="0" alt="Photobucket"></a>
PARTS to Convert SR5/Limited Ext. to Trail Edition
• --------Part Name----- OEM Part #--- msrp - online cost
• A.)Front Valence Panel 53901-35210 $143.52 -104.99
• B.) Front Bumper Cover 52119-35907 $246.01 -177.42...reported to have changed to 52119-35910
• C.) R. Rear Bumper Support 52155-35040 $40.53 – 29.23
• D.) L. Rear Bumper Support 52156-35040 $40.53 – 29.23
• E.) R. Rear Bumper Bracket 53723-35030 $65.82 – 47.48
• F.) L. Rear Bumper Bracket 53724-35020 $65.83 – 47.48
• G.) R. Rear Corner Flare 75653-35120 $46.07 – 33.24
• H.) L. Rear Corner Flare 75654-35120 $46.07 – 33.24
• I.) R. Rear Bumper Flare 52707-35010 $54.33 – 39.19
• J.) L. Rear Bumper Flare 52706-35010 $54.33 – 39.19
• K.) R.Rear Door Moulding(flare) 75741-35150 $67.19 – 48.47
• L.) L.Rear Door Moulding(flare) 75742-35150 $67.19 – 48.47
• M.) L. Rear Mudflap 76608-35110 $42.87 – 30.92
• N.) R. Rear Mudflap 76607-35110 $42.87 – 30.92
• O.) R. Rocker Moulding 75806-35100 $224.46- 161.94
• P.) L. Rocker Moulding 75805-35130 $224.46 –161.94
• Q.) R. Front Fender Flare 53847-35140 $142.70 –102.95
• R.) L. Front Fender Flare 53848-35140 $142.70 –102.95
• S.) L. Front Bumper Support 52116-35130 $37.75 – 27.24
• T.) R. Front Bumper Support 52115-35140 $37.75 – 27.24
• U.) L. Inner Fender Liner 53876-35120 $82.45 – 59.48
• V.) R. Inner Fender Liner 53875-35130 $87.63 – 63.22
• W.) R. Front Mudflap 76603-35050 $42.87 – 30.92
• X.) L. Front Mudflap 76604-35050 $42.87 – 30.92
• Y.) Rear Bumper Lower Cover 52169-35080 $123.66- 89.22
• Z.) Rear Bumper Cover 52159-35915 $277.64-200.30
• * not seen in pic because they are already installed on Front Bumper Cover
• *R. Front Bumper Cover Flare 52112-35150 $64.30 – 46.38
• * L. Front Bumper Cover Flare 52113-35140 $64.30 – 46.38
-------------------------TOTAL--------------------------$1890.55
• ** You will also need the outer dust seals,retainers and fasteners for the rear passenger doors.
• I don’t have them on mine yet so not sure of the part numbers.They are not really needed as there are inner rubber seals too. I will update when I go the parts dept and find out/order them.
• *** I don’t have the amount of plastic fasteners used as I reused a lot of mine and they
• ordered the rest. I do know you need a lot of 75392-35200 blue fasteners(at least 25,they call them retainers)
• and some 52535-0E030 retainers for the front valence.
You will have to ask your local parts dept for numbers and types of these plastic fasteners.
Please don't ask "how to do it" because I don't know how to answer that. I just did it from experience and if you have experience with body work it should'nt be a problem.It should be in the repair and collision repair manuals posted in the forum. If not sure if you can do it,print this out and take it to a body shop or have me do it for a nominal charge.
A couple of the R. for Right(passengers side) and L. for left(Drivers side) might be mixed up.Double check if your ordering just one side.If you find any errors or have questions ,PM me!Took me awhile to organize this but I did the best I could.
I have this online in my Google Docs in a word document if you want to download and print this here.... https://docs0.google.com/document/e...XR88HBEnD5_CthXEwsPJs&hl=en&authkey=CKK8_eoE#
Good Luck:cheers:
Here are some pics of the parts and the install.....Picasa Web Albums - harper7 - TE exterior C...
Reply to SeattleMike..... he's correct,the disassembly/assembly should all be in the repair or collision manuals posted here on the forum.
Also,as he mentioned, pretty sure the 4cyl front bumper cover(OEM Part Number 52119-35905) is the same as the TE(Part B) but doesn't have the slots and holes cut in it for attachment of the front valance(Part A).
Good Luck:cheers:
