I know most of you have already read this, but Gadget's site has tons of mods and great info on how to improve a Supercharged 4Runner. Here's the link:
Gadget's 4Runner
There's also lots of great info on AFR's, fuel mods, air intakes, etc. Lots of dyno runs to show what works and what doesn't.
hey guys anyone know how you got the rear case bearings out with out resorting to a blind hole puller. I can see how to get the left one out, but the other is behind the casting. Any help would be appreciated since I want to tackle this this weekend
I asked the same question a few pages back in this thread. Basically, you have to either fab up some fancy tool, take a risk and tap the back by drilling a hole (risk ruining your supercharger if you miss!) or ship it out somewhere.
This might help: https://www.youtube.com/watch?v=48a8QvPwbWQ
I was in the same boat. I recommend opening it up (it's very simple in there) and inspect the condition of the rear bearings. Mine still had plenty of grease and all the rollers and such were in great shape. There's no way to get both bearings out unless you do something fancy like mentioned above on the 2nd gen S/C (I have the same one). The rear bearings last longer than the nose cone. All the writeups on the front page don't mention how to remove the rear bearings since it's so difficult to do. I think some got lucky and had tools that just happened to fit, but I didn't want to ruin the bearings and since mine were good anyway I didn't do it.
I'm assuming you are changing out the nose cone with the Toyota kit? I forget where I read it but it's recommended to do every 100k miles. Did mine because it was getting really noisy at idle and the little oil that came out of it smelled like death.
Yea I did mine a while back and had pulled the pack then too. Like I said the bearings were good still but the recommended interval ( by anyone other than Toyota guys is 100k max) I will see what I can do I know I can do it without making a tool like that since it has been done I just need to remove the brass access port on the rear shown here and then beat both the bearings out.
I have plate bumpers full skids, bigger tire, and 300+ in the rear at all times and I still get 18 on the highway...
i dont know if you have a lift. but im sure your plate bumper is way more aerodynamic than my tube. also lights up top probably dont help. but oh well.
I haven't seen a good way to get the rear bearings out besides a special tool or drilling a hole. I personally wouldn't drill a hole just in case something goes wrong, but a tool seems simple enough. Maybe something like a snap ring plier that has hooks on the side so it applies outward pressure and can catch the lip on the needle bearing.
The 1st and second gen are different.. you can literally see one of the bearings from the back so no drilling is necessary... I just cant see the passenger one.... i think its behind that brass plate tho
yeah i was around 14 to start. i replaced my o2 sensor pre cat exactly a year ago because it was throwing codes.
im sure the tube bumper, light up top, 3" lift and body lift dont exactly help all that much anyways. but still 12 mpg sucks! im getting about 170 miles to a tank (13-14 gal fill ups) numbers dont lie.
EDIT: i checked this fill up last night. i did pretty good. 200 miles 13.7 gal fill up. thats right around 14.5 miles/gal.
Are you running any other fuel mods? I was debating between a meth kit and 7th injector. Couldn't decide. Saw a screaming seal for a 7th injector for $500 so I decided to pick it up. Meth kit may be done shortly after as well.
Have you installed your 7th injector kit yet? I ordered mine a couple of days ago. I received an email from Gadget stating the black box is currently in manufacturing. So the kits are on back order
I hope to receive my kit by the 14th.
I spoke to Gadget this morning regarding my current AFR readings. Seems the water meth system did help a little by increasing my AFR reading a bit richer but not enough to be comfortable.
I just went ahead and ordered the 7th injector kit. Its gonna kill me to pay that bill.
Gadget stated that the AFR reading at WOT should be 11.1. Im way off, showing around 13.9 to 1.
So did tuning with just the meth kit not work out too well (I thought you were going to try to just stick with the meth kit)?? A couple of us are in the same boat.. Right now the truck is running fine... But if I wanted a bit more power, I was hoping to get by with just the meth kit.
Why not just try a larger nozzle for your w/m kit before dropping that kind of coin on a 7th injector? What percentage of methanol are you running?
I have ordered a 5gpm nozzle, just waiting for it to get here.
I am currently running a 50/50 mix and my AFR shows 13.8 to 14.2 in boost! This is my concern. I was hoping to be at least in the 12's.
I'll keep you posted on the larger nozzle.
