4Reak Show
so I've been tossing the idea around of an electric exhaust cutout, basically i would want to do it before the cats, which in return would make it even better then a high flow cat and exhaust, also it would probably sound mean as hell. does anyone think this would be a bad idea ? also would it throw any trouble codes. haven't really looked a ton into this but i wanted to ask just to see what you guys thought about it
After my conversion install I drove the rig to the exhaust shop sans muffler/cat and I promise the 3.4's exhaustless sound very mean. However, you will set a code for cat efficiency and probably even 02/AFR performance codes as well. Simple enough solution: clear the codes, keep your exhaust cut out closed, and drive it for a couple days IF your area requires a smog test.
