Ausumm
I have searched and read through most of the threads here...
regarding LED headlights.
But I need to start a new one, because I am hoping to settle this argument once and for all.
In researching my wish to replace my headlights and fog lights with LEDs...
I keep finding conflicting answers.
Some say you simply CANNOT use LED headlights of ANY kind...unless you have PROJECTORS.
Because you will blind oncoming drivers.
So I would need to replace the headlight assembly(s) as well as the lamps.
Some say you CAN use LED's with the OEM headlight assembly.
But you need to use an LED bulb that has an adjustable beam...
you need one that addresses the beam pattern in some other way...
or...you can use them IF you don't really care about blinding oncoming drivers. :shocked:
Some also say you can use them WITHOUT projectors...
but you have to buy a certain brand or model LED.
And what's the story on "HALO LED" headlights? Is the circle of small LED's the only light source?
Or do they come with LED headlight bulbs.
Then, I read about LEDs "flickering"...
about the bulbs not fitting because the back end is too large to fit...
I see where people wanted to, or had to...modify the dust cover, the bulb, or some other part...
I read one post where someone's truck didn't pass inspection...
Remember, there is a difference between
a FACT
an OPINION
a RUMOR
a PERSONAL EXPERIENCE
an EDUCATED GUESS
and an UNEDUCATED GUESS
Can SOMEONE please tell me THE TRUTH!
a FACT
an OPINION
a RUMOR
an EDUCATED GUESS
