The Official Build Thread
just looking at that roll bar makes me wanna see you hack the back end off and make a soft top for the back but take it off for summer cruisin...that would be Sick!!!!!!!!!!!!!
Big Rig.... :lookout:
Gray Rock ORV in Mount Olive, Al.
More........
SO SICK!!!!! i love it!!! is that sonoran steel lift bigger then an OME or toytec ultimate??? and to get 35's is there so such thing as a body mount chop needed to be done like on 4th gens or if there is enough clearance they can be thrown on???
I think I have read this whole thread about 2 or 3 times and all I have to say is WOW! I am in love with your rig! I want to do something like that minus the bumpers, it's still techniquically my dads :(. I love the Rola Rack on top! I also like the lights that you mounted. Could i get more info on that? Thats either first or second on my list to do. I also want to get the Toyatec adjustable lift. OH and the wheel spacers add A LOT! It give it such a good stance. What wheel spacers did you get? Well sorry for all the questions but I just love your rig and want mine to be something I love just as much. Thanks alot.
He sent me the link on the rack, Rola Roof Mounted Cargo Basket Rola Roof Cargo Carrier 59504
BTW dude u on facebook, a lot of us are join the group: Toyota 4Runners! | Facebook
Thanks for the compliments. The rear of the Sonoran is the largest amount offered in a "kit". I believe the front is close to the same ont the Toytec, OME and Sonoran kits. Check out Steve's FAQ on his site for info. He's put together quite a list of answers there. And to get the 35's to "fit" (they still rub at full lock and under compression) I cut the fender liner back, trimmed and pounded the pinch weld and the corner of the firewall / fender area. No mount chop though. Again, thanks man!:reddance:
Thanks for the comments bud. On the Rola rack : I bought the lights, bought new, longer hardware at HD, drilled thru the main bar, hit the bare metal with paint to prevent rust, found some sweet rubber grommets that fit in the holes to make it look semi-professional and help keep water out, and mounted the lights. I ran the wires together down the rack and into the rear hatch. From there I went to the dash and have them wired on 3 seperate circuits. 2 outer front, 2 inner front, and 2 rear. The Toytec stuff is great. I love my Sonoran lift. Rides great with the added weight of the bumpers. Hope that helps, lemme know if you have any more ?'s... I'll be glad to help out.:reddance:
that ride is disgustingly sick, how come i havn't seen this one much on the fourms
I hope that means you like it? And I work alot. Then school. Then working on the truck. Not much time to post a bunch, I'm working on it though!
Yeah, I'll join up... Ya'll can add me too - Chris's Facebook
thanks for the answer back chris. cant wait to get rid of the preRunner 4th gen and get my 4wd 3rd gen :) oh and u prob already knew but your truck is famous as its on sonoran steels site haha
hey chris gotta question for ya.... do you absolutely have to re gear after putting on 35's on a 3rd gen or can you drive it with stock gears for a good while? also what gears do you have in it? 4.10? thanks!
thats what i thought.... cause re gearing is expensive and i know you can just do the rear if you dont have the funds for both but then your stuck in 2wd until you can pay for the front to be re geared.
I wouldn't do just the rear for now to save $$ because all it takes is to forget once and you'll blow up your t-case. Or if you let someone borrow your truck and forget to tell them, you just never know - I would wait untill I got enough $$ to do them both together if I were you.
