The Reaper build
monkracing29
So after a full year of owning i am finally getting around to put my build of my 99 desert dune limited. will be updating as the day goes
Exterior/Wheels/Tires/Brakes
Removed the running boards
Bronze Method MR312 17x8.5
Nitto Ridge Grapplers 285/70/17
ToyTec rear brake line
13WL Tundra Brake Upgrade
Custom Full length roof rack
Hid Projector upgrade with halos and demon lights
Led Wrapped CB Whip
Turn signal conversion with switchback leds
Led rear Tail light
Led bulbs all around exterior
LedConcepts rock lights and grille lights
Smittybilt 9500 hidden bumper winch
Smittybilt element traction boards
4Wheelparts Hilift jack
Baja design squadron sport for lights
Morimoto ditch lights with SRQFAB bracket (waiting for Baja design XL80s)
double Auxbeam 30 inch lights on roof rack
rear 30 inch led light bar
Sports Hood
windshield replaced 3/12/18
Interior/Electronics
JVC headunit with rear view camera
dash cam
Pioneer under seat sub
Python 2 way remote start
LED dome light replacements
LED Lighting in the dash
Axe/Shovel mounted to inside of rear hatch
Under the Hood
all gear diff fluids changed to royal purple
Suspension
Icon 2.5 EXT coilover
Icon lc80 rear shock
OME 861
SPC UCAs
Sway bar end links 2nd gen
New Lower ball joints (OEM)
New steering rack with
New Sway Bar Bushings Front/Rear
Steering Rack Bushing Kit
Whiteline bushings in Front LCA
Whiteline bushings in all rear suspension components
Spidertraxx black spacers
Mods to come in the future
Rear cargo box
Dual battery with solar panel
Vair compressor in rear cargo box
New full suspension with remote res and clickers
2 inch tapered body lift
Sliders
Scan Gauge II
Maintenance
new fuel injectors 2/13/17
new valve cover gasket 2/13/17
most vacuum lines replaced 1/15/18
When i first purchased the truck 02/05/17
after i replaced shot suspension with the tundra lift, the hood, front bumper and got her running correctly. I went out and bought some stock 5th gen trail wheels and my first set of hid projectors
04/11/17 went out with a few local buddies to the Overland EXPO in Flagstaff,AZ got my overland coin!!!!
went out to Broken Arrow trail in Sedona afterwards
put it up a little to much of an angle and had a strap attached just in case the truck wanted to tip but had no problems at all.
After the run at broken arrow found out i had a bad steering rack and lots of bushings that tore my new tires apart so i found a used set of K02s.
added a new light bar to the back of the roof rack
Also removed all the gold emblems and plastidipped them and my new trail emblem purple
So the second part of the name of my truck after getting her being at the brink of death and rebuilding her she took her first life of a PT Cruiser that rear ended me on the freeway. The driver tried to blame me saying i hit his car unattended in a walmart parking lot
the driver tried to run from me but my hitch punched a hole in his radiator so his car died in a parking lot
but my hitch punched a hole in his radiator and bent it back into the motor so his car died in a parking lot
not much damage to my rig bent the rear bumper guard that i mended myself
AndiGarage
