Thinking og getting 20' Tundra rims on my 4runner...
daytonaSURF
I was looking at the 20' Enkei Deep 6 Rims. They look soooooo good! I was looking to get them put on my 1998 4runner. Do they or dont they bolt up? Ive been looking around and I should be able to get them pretty cheap... hopefully. Thanks in advance!!
Yeah i have those wheels on my 04 and there awesome, im not really sure what you mean by bolt up??? explain that to me and maybe i can answer that question. or im sure someone else here can. what kind of tires you thinking about running with? I must say tho that you have very good taste in wheels!;): :D
By bolt up, I mean just go on to my 4runner w/o any modifications? BTW, I dont have 4x4. How much did you spend on yours?
They are not going to bolt up. The bolt pattern was changed from your model 4Runner. Why? Because those wheels fit my 03 4Runner, and our bolt pattern is different than yours.
Sorry,
joseph
daytonaSURF said:
But both are 6 lug so they should, right?
the distance between the bolts are different. if you draw an imaginary circle through the center of all the bolts, the diameter of the 3rd gen won't be the same as the 4th gen.
for example: a bolt circle of 6x150 means 6 lugs with a diameter of 150mm
AHH!! Man I got my hopes set up the past week or two hoping these things would fit! :( Theres absolutly nothing I can do about it huh? Do you think Enkei makes these in a different pattern?
i just checked on tirerack.com and it looks like the 3rd gen may very well have the same bolt pattern as the 4th gen. i looked up a 98 and an 03, they both showed a bolt pattern of 6-139! i have to leave work right now so i can't really confirm but you could check into it further online or on tirerack. good luck!
Yea i've been looking around at it and everywhere says the Enkei Deep 6 fits on all Toyota 6 lug vehicles. If anyone can confirm this or anything please let me know!
6 x 139mm same as 6 x 5.5"
Should be same fit lug pattern. I would be more concerned with the wheel offset and width of the new wheel. I am pretty sure the stock 17" 5 spoke alloys have a 7.5" width. Not so sure about offset though. I have put my16" wheel purchase for winter tires on hold until this can be totally resolved. I don't want the inside of a wheel rubbing on the suspension or the wheel well at full lock.
yes, the 9.5 wide will fit on 03-05 4R. but! you have to get the deep six in an 8 offset! That what the TRD 20" is .the 15 offset that most place carry and enkie has on they wedsite will hit the caliper.. I call several places and they never herd or seen an 8 ET. they all said that Enkei only make them in an 15 ET. that just to show you want those moron at discount tire direct know!
A buddy of mine have the Enkei deep six that is 15mm offset with 108mm bore on his 96 4Runner. Will the same wheel with those same specs fit on a 05 4Runner? Thanks!
workingwheelswnc
