It takes me about 4-5 months to reach 5K miles.
As I just changed the transfer case and diferential to synthetic and really like the change I'm contemplating changing the engine oil to synthetic as well.
With my job I will drive 1000-1250 a week when busy and a good 90% of that is highway miles cruising. I would change my oil and filter every 5k.
So I'm curious what intervals folks are using for synthetic?
Are you using a special filter as well?
Thanks from the synthetic rookie!![]()
I have a 2003 4Runner at 255k.
I have been running Mobil 1 Synthetic at 7500 intervals until about 06 or 07 and have running Mobil 1 Synthetic Extended Protection at 15000 mi intervals since then.
Most importantly, check out Welcome as previously mentioned where you can find REAL data oil performance that will clearly demonstrate improved performance of modern synthetics (ie, everyone's newest top of the line $7/qt) as well as demonstrate that they can be run successfully at intervals MUCH higher than 15k if desired.
So what does pure synthetic buy you that synthetic blend won't suffice?
No, I haven't increased my oil change interval. I change the oil at 5000 miles and the vast majority of the time it's with Mobil 1.
Why? It's only a couple of bucks difference, the light is annoying, it's a good time to rotate the tires, the cabin filter needs to get changed, etc.
Could I use dino and save myself the $10-14? Sure. I could also feel safe going to 7500 (e.g. cross country road trip doesn't fit into a 5k interval) w/o worry on Mobil 1
$40k vehicle and I'm going to complain about an extra $14 every 5k miles? Hahaha. I can use 87 compared to some of our competition and that's definitely more than $14/5k (5000 miles /18mpg x $.2/gal diff = ~$55 for 92 oct)
I didn't see it mentioned, so I will ask -- Is there any potential benefit in gas mileage due to using synthetic oil versus conventional oil?
I could be wrong, but it seems to me that I read that Toyota is putting synthetic oil in the 5th Gen 4Runner OEM in an attempt to push the gas mileage average.
Are you doing a filter change at 7500mi or running the filter the whole 15k?
I see what you're getting at here man, but the point of not having to service your vehicle that often makes it's own stand. Is there a huge monetary difference? No, not really. But I don't want to spend more, AND reap ZERO benefits from it. It's kind of like people that always fill up their tanks when they get to halfway. Why would they give you an 18 gallon tank if you only use it for 9? You're literally throwing away (or recycling, since I see you're in SF), PERFECTLY GOOD OIL. If you use the 5k interval for other routine maintenance on your rig, then great. But switch to dino so you're not wasting money.
