Throttle body/IAC cleaning
Robmills72
Planning on pulling the throttle body and Iac valve tomorrow for a little tlc. I'm planning on using carb cleaner since I can't find tb cleaner to save my life. Any tips/tricks for me? Just not wanting to mess anything up. Also, what would I clean the iac with?
Cheers
From what I remember reading, the biggest thing you need to worry about is messing up the TPS by getting carb cleaner on it. The solvents can mess it up. I also replaced the little grommet on the idle adjustment screw. I don't know if it helped anything. The old one was a little loose.
For the IAC valve, I may have used carb, or brake cleaner, I can't recall. You might want to find a write up. From what I remember, there is a little rubber gasket on the end of the valve that that helps it seal. The biggest thing with the IAC valve is to use compressed air to blow out any junk that may have accumulated in the passage way. When you first start your truck up after the cleaning, it may surge a bit until the thermostat opens up and pumps coolant to the IAC valve.
Just got done cleaning it and man, it was gunk galore! Anyway on a positive note my idle is back down and I have noticeable little gain in power
NVBASSJUNKIE
