Thump went the XREAS suspension
Ares0311
This past weekend my suspension got progressively worse and by the end of my trip the front passenger shock was dead. By Sunday on my drive home it thumping over every bump so I automatically think blown shock and I brought it in to the mechanic to look at.
They had the vehicle all day and when I go to pick it up they said that they test drove it and felt the thumping, put it on the lift and checked it over every thing was tight and the shock wasn't leaking. But advised me that I needed 2 new front shocks.
Next day, I dropped it off to another mechanic that I have used for a long time. He did his thing drove it, felt it, lifted it, checked it... then he rotated the tires, made sure everything was tight and called and told me that he knows that there is a problem, but didn't advise me to change the shocks out because it could be a loss of money if that wasn't the problem and I could end up chasing my tail.
So I have 2 different opinions, one wants $1200 for two front shocks and a wheel bearing that "will cause me problems down the road" and the other one who basically said hold off until you can diagnosis it better or just start replacing things until it goes away.
Now reading up on the forums, I am also thinking that it could be the sway bar bushing or control arm bushing. Is there an easy way to rule those out?
The truck is a 06 Sport Edition with 74,000 miles on it.
You cannot just replace the front two shocks. The right front is connected to rear left and the front left is connected with right rear.
What makes you think the shocks have failed? Does the car bounce forever after going over a bump?
Do you just hear a thump while driving? Check the ball joints.
I have a BRAND NEW Xreas system that the stealership just installed on mine that I will be more than happy to sell you $1200. A new system will cost you over 3K to install at a dealership! I want to go with the ToyTec Ultimate 3" lift.
Is that obx as in the Outer Banks or North Carolina? Not a fisherman but went surfing there quite a few times. Beautiful place.
I wonder if you get give us a report after you install your Toytec Ultimate. I'm very, very intersted in doing the same lift, and also have XRES. I'd really like to know how the Toytec system compares for off road handling, and I'm thinking other people here would be interested in the same thing.
Thanks, and enjoy your new lift.
Yes OBX stands for Outer Banks. My parents live down there and my dad runs a fishing pier so I frequent the "OBX" quite often!
Makes me happy to have just the standard shocks setup after reading this. 135K and still ok for now, but probably going to replace them soon.
<snip>
Any idea what caused it? Do you off road, auto-cross, etc?
Sorry for the late response, I've been away for a bit.
I was thinking shocks because it does bounce forever after going over a bump. But now it also seems to sway left to right, much like being on a boat at sea. So now Im thinking sway bar, tie rods, or control arms...
I do not autocross or off-road, but I think it was from the roads up here in Maine.... Some of them we use to get to climbing areas are tarred but might as well be considered rock crawling....
Still no definite answer.... Going to bring it to the stealership to see if they can at least narrow it down.
Thanks,
Adam
1200 dollars for two front shocks? What? I would find another opinion. For a $1000 installed you can have Old Man Emu shocks and springs installed that kick the hell out of the stock suspension. Or just buy Bilstein 5100 shocks all the way around for $500-$600 installed. No way I would recommend replacing the xreas system especially for that kind of money. No way.
goddesszilla
