Time sert insert size confirmation 5VZ-FE
NuMex00
Looking for confirmation on the correct insert size for a time-sert insert for a stripped spark plug hole on a 5VZ-FE. I measure 15mm (0.600", part number 44129) from the washer to the last thread, but from the little info i have found, the 16.8mm insert (0.660", part number 44111) seems to be used in many toyota applications.
I really dont want to thread the wrong length insert into the newly cut threads, so a little confirmation on which is the correct insert would be greatly appreciated. If you have done this before and remember what insert you used let me know.
Thanks in advance
ghengiskhan
