tkr128 is correct.tkr128 said:On Toyota's maintenance book, it says to replace the timing belt every 90,000 miles. If you look carefully, it says it applies to 4Runners with the 2UZ-FE engine, which is the V8. So if you have the V8, you have a timing belt. The V6 uses a timing chain.
I test drove a new 4cyl Accord and the first thing the salesman told me is the new engine now has a timing chain which of course much better. :rolleye2:Jim_Chow said:Hmm. Wonder why toyota went w/ a chain in the new V6? Maybe they're admitting that the chain is superior to the belt? The 3.0 liter toyota (hino) turbo diesels used in overseas 4Runners/hilux pickups use t-belts.
I think that is just spin, when manufacturers started to use belts instead of chains they made exactly that claim. It makes valve timing more accurate, quiter, etc, etc.MicaBlue03 said:I believe I recall Toyota saying that they used a chain on the V6s (which have variable valve timing) for increased timing accuracy or some phrase such as that.
With the switch to variable valve timing on the V8s in the 2005 model year, have they changed to a timing chain?
peter78 said:
V8 timing belt and it is a INTERFERENCE engine, meaning if you go past 90,000 miles and it breaks your are looking at the cost of buying a re-built engine.
bulldog-yota said:I think that is just spin, when manufacturers started to use belts instead of chains they made exactly that claim. It makes valve timing more accurate, quiter, etc, etc.
Now more and more of them are going back to chains, for simple maintenance issuesThe biggest advantage with chains in my experience on various engines has been that it normally give you warning before it pops, belts just fail on you with no warning. You obviously have to listen for it, but you can hear when a timing chain is not happy.
I wish the V8 used chain(s) instead of a belt. Now it will cost a pretty penny at 90k miles to change. I looked at my motor the othe day, when trying to figure out what my PS is doing. It looks like a major effort to replace the timing belt.
peter78 said:I test drove a new 4cyl Accord and the first thing the salesman told me is the new engine now has a timing chain which of course much better. :rolleye2:
When you look at the cost, the 3 people that I knew opted for a re-built engine. It was a bit more, but the cost of the repair might even go higher. Usually the cost is within a couple hundred dollars. The good news is the 3 cars went another 100,000+ miles.Hitman said:If your timing belt breaks, you will not need a new or rebuilt engine. Typically, the only thing that happens is that the pistons make contact with the delicate valves, which results in bent valves in the cylinder head.
It's not cheap to fix, but usually the head needs to be rebuilt or replaced. The engine itself should be fine, however.
I've worked on a few "interference" heads with broken timing belts in the past.... the most recent being a Nissan Maxima. Total cost for repair was about $1600
The engine was quite quiet, less noise than my old 92 model. Decent power, 160 HP. The salesman did not know if the engine was a interference or non-interference engine. If fact he didn't know what interference meant.Hitman said:I wasn't aware of Honda using a timing chain on their 4 cylinder Accord engine, but I guess it is possible. But I do agree that it is definitely better than using a belt....just a little more noisy though...
Hitman said:One of the main reasons that belts became so widely used is the fact that they are much quieter than chains. Accuracy is not a factor for either belts or chains. Both are very accurate.
Chains are obviously more durable than belts, which is why manufacturers don't typically list a replacement interval for chains.
An experienced mechanic can hear a worn timing belt, believe it or not. I learned that years ago from one of our most experienced techs when I was working at Toyota.
