the great him
Elite Member
you can tq it the same method, bump the starter...
Ya but what are you going to do when you have to torque it down to 217ftnlbs? Well to replace the front main seal you have to remove timing gear. I tore it down because my crank pulley was wobbling so I thought it. Was loose which it wasn't, woodruff key was worn so I replaced it. And replaced pulley but I still have the wobbles. It's the same thing as doing a tb job. i just reused my timing belt. Also make sure you have it on the correct side when you bump it loose.
Good question guess I'll see how tight I can tq it down before needing a special tool..
Now it makes sence lol
I have done a fair amount of work on engines where I have had to remove the crankshaft bolt and I have never torqued them back down when re-installing them. I use an impact gun and hammer it down for a few seconds and call it good. I have never had one come loose and they are always tight enough to where I have to use a breaker bar and some muscle when removing them again. There are only a few things I use a torque wrench for on engines which are ALL engine internals, head bolts, clutch pressure plates and maybe a few other misc parts here and there. For the most part, hardware is either German torque or thrown on with my impact gun.
There was an SB for 4runners i believe where their original torque on the crank bolt wasn't enough which was 160 IIRC so they upd it to 217. What's your impacts max torque at?
I'm not sure, it's a beat up craftsman impact gun so I don't think it gets anywhere near the 200 mark. But since you mentioned that I'll keep a very close eye on it for a while.
I do have a electric impact rated at 500ftlbs maybe a little to much? Lol
I'm confused how would re tq down work the same way? Motor only rotates one direction?
