thequickad
Does the metalic cap on the tire pressure sensor serve any additional purpose? Like antena extension, signal grounding, ...etc?
Am I reading too much into this technology?
thequickad said:![]()
toto said:I'm actually concerned that they're not plastic...
but then replaced them all with plastic ones after they found that the road salt used in winter climates caused the caps to corrode and get stuck.
Ruben said:What year and which models came with the Tire pressure monitor sensor? I am getting a set of sport wheels from a member here and I was just wondering if the wheels come with the sensor can I get the other parts that show the presure warning light. Any advice....
leftyrb said:My 2004 came with metal caps, but my 2005 came with plastic caps, so there you have it - Toyota changed them for the 2005 model year
Yes, you are correct, sir!Uneek said:I believe 2004 and newer on all 4R trims.
