E
Even Steven
Guest
Does anyone know the size of the battery for the tire pressure sensors inside the wheels? I'd like to buy them ahead of time to swap in new batteries when I switch out my wheels.
toto said:According to Toyota, you'll destroy the sensor in the process of opening it to replace the battery. You'll break the silicone resin seal on the circuit board, and the battery is held in by conductors that are soldered in. Bottom line, the sensors are disposable.![]()
boston_kevin said:I'm not 100% sure, but I believe these sensors are supposed to last a minimum of 6-8 years.
toto said:Yes, that's right. FSM says 5 years.
boston_kevin said:Ouch!! 5 years and I have to replace 5 stems at $100+ each and have the stealer reprogram? Sounds like very expensive maintenance to me. Probably looking at $700 just to replace the stems!
toto said:
I wonder if the 10 years is just optimistic thinking, possibly caused by negative reaction to 5 years. The first ones came out around model year 2003, so I guess we'll find out soon.
I didn't think 4Runner was first to get active TPMS, but I guess it is; other models all came later. You're right - 4Runner got it in model year 2004.
My 2013 RR TPMS battery lasted 5 years, wish it was 10 years. A dealer does not have to do this work, part without labor at a Tire Discounter is $ 76.00. Yes it can add up and be expensive.
i still have the original for my 2005 4runner. its 12 years and counting.Interesting... Toyota is publishing conflicting information.
The 5 years came from the Factory Service Manual.
The 10 years is mentioned in PG004-06 (posted in this thread).
My OEM sensors lasted 12 years as well
