Tire Size
Pyrohazard
What size tire can I fit with a 3" lift, also what size wheels should I go with.(I was thinking 20") What is a good brand of wheels?
so why would you get a wheel size that cuts down on your sidewall area if youre going to wheel in the ROCKies...? :confused:
If you truly off road then don't go bigger than 17" since you do need some sidewall to bea able to rub on rocks.
Ok I see what you are saying about the side wall space, But can I fit like a 33" or 35" tire with the 3" old man emu kit?
35's if you trim the crap out of your truck...
33's w/ 16" wheels, probably w/ slight rubbing.
I was told by my local 4x4 shop that I can not do a BL because the 4runner is a Unibody. But from some of the lift kits I have seen I am assuming that you can do it in the front. Is that what you are recomending?
Also when I get the 33" tires on, the speedometer is going to read a 15% difference. How do I go about recaliberating it? Is there kits that I can use or what?
4Runners sit on a real frame and you can tell by looking underneath.
Where in Colorado are you as there's alot of guys who've done a ton to their Runners around here that can give ideas.
Also for more off road advice check out www.yotatech.com
tell that 4x4 shop to close down because they are retarded! hahah. it is NOT unibody and you CAN do a BL.
anyway, as for your speedo, you cant really recalibrate it... what you should do is if you have access to a GPS device, ride with it on and see what the actual MPH difference is. then just bear it in mind.
That guy must own a Cherokee. LOL!
Actualy yes you can recalibrate it. www.DakotaDigital.com
Electronic Speedometer Adjustment Module $109.95
